Can't navigate book
Guest
Feb 19, 2015 Feb 19, 2015
I've downloaded a book, but can't turn pages, or navigate book via table of contents. I had a similar issue with another textbook reader and I had to change my preferences to 'use software based rendering' but I can't see how to change preferences in Digital Editions.
Danielle
2.9K
Adobe Employee ,
what is the format of the book on which you are facing this issue (pdf or epub) ?
You can check the book type in item info dialog.
Please check the following:
1. Open the file in Adobe Digital Editions.
2. Go to File -> Item Info
3. Check the book name and extension under "Location"
Guest
Feb 22, 2015 Feb 22, 2015
Sorry - it's a PDF document.
Adobe Employee ,
Which version of Adobe Digital Editions you are using ?
Guest
4.0.3.110333
Adobe Employee ,
Ideally, turning pages in ADE should not be a problem.
Still, if you are facing the issue, i think machine restart should address the problem.
Please restart your machine once and try.
Thanks !!
Guest
Thanks. I have restarted the computer twice now, and still the same problem.
Adobe Employee ,
You are using ADE on windows or mac and their version ?
You trying to navigate using scroll bar on rightmost side of ADE / mouse scroll wheel / arrow keys on keyboard ?
Guest
Using on Windows and using the windows version. Have tried navigating by Table of contents, scroll bar, mouse scroll wheel and arrow keys, but same problem...
Thanks for your help...
Adobe Employee ,
The book on which you are facing the problem, is it a free book or paid book?
Guest
It's a library book through Ebrary. A 2 week loan.
Adobe Employee ,
You are using Windows 7 or Windows 8.1 ?
Guest
Windows 7
Adobe Employee ,
Feb 23, 2015 Feb 23, 2015
is it the only book you are facing this problem or with other pdf's also ?
You can try by opening any pdf in ADE and try navigation.
Guest
I have an identical problem. I have Windows 7, and have tried restarting and reinstalling.The problem occurs for any pdf, even the "Getting Started" document.
The page number will shift when I press the arrow key, but the page view will not change. If I resize the window screen, the page view will update to the correct page.
Guest
I have this exact same issue as well. Resizing, or closing and re-opening the application fixes the issue
Guest
Thanks Reym, but resizing or opening and closing doesn't fix the problem for me. I have tried other documents including epub. Same problem.
Adobe Employee ,
try going back to library and open the book again
Guest
No luck.
Adobe Employee ,
ok, now let us compare the system environment as this issue should not have happened.
Do you have any service pack installed for Windows 7.
You can check this in:
Control panel ->System-> View basic information about your computer.
After checking this, check version of Microsoft .NET FRAMEWORK version.
You can check this under: Control panel->Programs and Features -> Uninstall or change a program.
Just check the version number.
Guest
I have Windows 7 enterprise Service Pack 1 - same as your image.
Microsoft .NET FRAMEWORK version: The 'name' column says 4.5.2, the column entitled 'version' says 4.5.51209
Adobe Employee ,
ok, then there is no problem with system environment.
now uninstall ADE and then re-install it.
Guest
I tried that yesterday - unless there's something different you want me to do?
Adobe Employee ,
I hope you are uninstalling ADE from control panel !!
Guest
Yes, >control panel >programs and features etc.
