I am a language intructor, can I use Adobe Presenter to work properly on both, English, and Spanish presentations with the same software?
Feb 23, 2015 Feb 23, 2015
Presenter
201
LEGEND , Feb 23, 2015 Feb 23, 2015
It shouldn't be an issue. Ultimately, Presenter doesn't care what language the content or audio is in, it will deliver it just the same. The only issue I could see causing problems would be the player skin. It has Spanish lables, but they only show on a computer with the OS set to Spanish. If you want the student to view both and English and a Spanish version on the same computer, you may need to have two versions of the language.xml file where you have one that has the desired English lables in
It shouldn't be an issue. Ultimately, Presenter doesn't care what language the content or audio is in, it will deliver it just the same. The only issue I could see causing problems would be the player skin. It has Spanish lables, but they only show on a computer with the OS set to Spanish. If you want the student to view both and English and a Spanish version on the same computer, you may need to have two versions of the language.xml file where you have one that has the desired English lables in the "en" section and one where it has the desired Spanish labels in the "en" section. You would then swap these files in and out of the folder located at,C:\Users\{UserName}\AppData\Local\Adobe\Adobe Presenter\Themes , as you need to publish an English or Spanish presentation.
Feb 24, 2015 Feb 24, 2015
Thank you very much. It sure helped.
Help resources
