Adobe Digital Editions page navigation issue. We are a large University running OSX and PC as many versions as you can think off including students byo devices ADE versions vary but the issue stays the same
There are certain areas that can gain focus and will "eat" the navigation commands, and it isn't always obvious when those areas have the focus. For instance the text controls for the current page and find. However the worst is probably the book information display in the table of contents.
This does not fix the issue
Intermittent causes to happens if client has switched to another application and back while digital editions is open
I get 30 minutes of reading it, and like clockwork the arrow keys stop working
This is a costly bug and we would appreciate a fix or at the least a work-around.
Dean Johnstone,
IT Support Consultant,
ITS Desktop Support Services
University of Otago
Thanks for reporting the issue.
Are you facing this issue with all book types (pdf, epub2, epub3) or with one of these book types ?
Please mention the ADE version you are using.
Once we receive more details, we will try to reproduce and fix the issue.
Thanks !
Adobe Digital Editions (ADE) software is required for temporary downloads of proprietary ebooks that have built in Digital Rights Management (DRM). This mainly affects ebooks the Library purchases from aggregator providers EBL, ebrary and EBSCOHost.
ADE is installed on some academic computers in the Departments, on some staff machines in the Library, with the bulk of use from University users on their personal computers and laptops.
Different versions of ADD will be in use on Campus.
We have tested both ADE 3.0 and 4.0. Ebooks are still downloading correctly and will open in ADE. However, there is no way to move through the book. The navigation tools are still active but do not effect the required movement within the ebook content. By this I mean that the scroll bar moves but the book does not. The table of contents navigation tree can be opened but does not work. Jumping to pages in the bottom tool bar does not work, and neither does using the search functionality
However, we have found that changing the Page View display will move to the required page. So, typing in a page number, hitting enter, then changing the Page View works; as does using the table of contents navigation tree and then changing the Page View
We are facing this issue with all book types (pdf, epub2, epub3)
I am having this exact same problem as listed above. "Page up/down" does not chage the problem, the only way I can toggle through the pages is if I minimize or maximive my window. This is a nightmare and hope there is a solution!
My solution was to contact the vendor of the textbook I had purchased, as they had their own proprietary reader (Emonds). I wouldn't expect any help from Adobe since these messages have been up here since 2015!
Please try "Page up" and "Page down" keys for navigation.
let us know, if this addresses your navigation issue.
Thanks !!
dont you think you should have an option for buttons using to click rather than using page down or page up option so that its easier for usage in tablets?
I can't believe I paid $100 for a text book that is shackled to the horrible reading experience that is ADE.
Is it just me or was it once possible to use arrow keys and scrolling to navigate pages?
I am having the same problem. Nothing works. Not PageUp/PageDown, not the menu options, not the scroll bars, not the mouse or mouse wheel.
This has been a known issue SINCE 2013.
This issue means that I cannot read the book I am required to read.
Issue still remains 2021-10-12. Supposed to read a document via ADE for an online course, nobody in my workgroup can navigate the document.
You can scroll and change pages but the page doesn't update until you resize your page view.
So if you're like me and searching for a fix, there is none. This problem has existed, apparently, since 2013 and there is still no fix for it.
Good luck
