"I was thinking to use cf report builder, however, the report
builder
runs only on windows if I understand correctly and my
coldfusion server
runs linux."
You say your server is Linux, what is your workstation? Yes,
the report
builder (the IDE for building reports) currently only runs on
Windows.
But the reports themselves, once built, can be installed and
accessed on
any server supported by ColdFusion. So if your workstation is
a windows
machine you can use this option if you like.
The cfdocument tag basically takes a HTML page, wraps it up
and spits
out a PDF (and other formated) document with some other
printing type
options. The CFDJ, back when it was decent, article I am
referring to
was how to make a basic HTML table based layout for
generating Avery
labels. It should then follow that wrapping this in a
<cfdocument...>
should also work. This may or may not give you more
functionality and
control, I do not know.
Unfortunately it has been many years and a couple of job
offers since I
did anything like this so I can not give any specific
examples or code
hints. Hopefully Google will be generous.
I have a vague memory of possibly using MS Word's Avery label
feature as
a staring point? That you exported the Word Avery template to
HTML and
started from there. I am not sure. This may have been before
Word was
as bad as it is now with extraneous HTML markup.
