So, I have a one row, 2 column table. In the second/last column, I have an image that needs to be bottom and right aligned. However, no matter what I do, I can't get the image to sit at the bottom of the cell.
If I add columns, and move the image to one of the inside columns, it bottom aligns, but if I then delete the column to the right (so that the image is now, again, in the last column) the image again is not bottom aligned.
I have tried giving the image a negative bottom margin, but that isn't working.
here's the code:
<td class="last" style="vertical-align: bottom;"><a href="#TOPofPage1"><img
src="../RESOURCES/i_SPECIAL_art/RETURNtoTopIcon.png" alt="" class="TOPofPage"
style="margin-bottom: -12px;" /></a></td>
here's what it looks like:
So the orange circle with the white triangle needs to be resting at the bottom of its column... why isn't it?
When I copy your cell code and just change the image to a plain triangle I have, the bottom alignment and negative margin work correctly.
Check other styling in the tr and table tags, and also any of the styles applied to any part of the table - maybe something there is setting the alignment of the cell.
If nothing looks obvious, perhaps copy the whole table to a fresh test project to see what happens, and gradually add back in your styles to see if you can reproduce.
THANKS AMEBR.. i always forget that "put it in a new project thing!" lol
