Hi to the Adobe FB team,
I've received the following message from Apple :
Dear Developer,
As we announced in October, beginning February 1, 2015 new iOS apps submitted to the App Store must include 64-bit support and be built with the iOS 8 SDK. Beginning June 1, 2015 app updates will also need to follow the same requirements. To enable 64-bit in your project, we recommend using the default Xcode build setting of “Standard architectures” to build a single binary with both 32-bit and 64-bit code
Is there a new SDK version planned to solve this ?
Thks in advance for your answer
Best regards
Bruno
Have you made any headway ? We're encountering the same issue.
Thought I'd update you in case you hadn't yet seen the fix.
You can grab the AIR 16 update and manually update the Flex SDK w/ it.
Refer to this article for help in replacing w/ the latest.
https://helpx.adobe.com/x-productkb/multi/how-overlay-air-sdk-flex-sdk.html
