I've been working with my developer to implement CSH responsive HTML by calling topic URLs. He said this was working just fine when he initially consumed my files. Now that I've done an update, he says they are behaving differently. He's calling the topic within an iFrame and, when he does this for any topic other than the default topic, the topic displays, but he doesn't get the help framework (TOC, glossary, etc.). For example, his call is to this directory: !SSL!/Project/topic.htm
He says that he can call it like this !SSL!/Project/index.htm#t=topic.htm then the topic displays just fine, but the window resizes when he click the TOC or any of the buttons within the help framework. Perhaps Willam van Weelden can assist?
RH 11.0.3 changed a lot. You can still call a topic, but it will redirect you to the start page of the project. In RH 11.0.3. Adobe introduced an iFrame to show topic contents where RoboHelp used to have completely separate pages.
The attributes for where the topic has to be opened is set in the scripts of the different widgets. For example in toctree.js, on line 338 and 345 the target is set for the TOC.
I'm surprised the option _self is giving you problems. I would expect that to work.
I think Ad
...Copy link to clipboard
I'm using RH 11.0.4.291.
You got all the latest RH patches for browser security installed?
I checked for RoboHelp updates just an hour ago, so I believe so.
My developer and I implemented per these instructions: http://www.wvanweelden.eu/articles/context-sensitivity-multiscreenresponsive-html5.
I believe I've encountered a bug against version 11.0.4. Here's what I've found:
I'll wait a day or two before I submit this as a bug. Please let me know if you see the same results or if you have additional information.
I think Adobe didn't consider it a scenario that Responsive help was to be opened in an iFrame. I recommend you file a bug report.
Willam, thanks for the information! We want to display the help within our web app and leave the pane open unless the user closes it. Do you have another suggestion for how to do that without using an iFrame?
Unfortunately, other than popups, new windows and iFrames, I don't see a way for this to work. Perhaps someone else has an idea.
