6
how to remove decimal value (.00) from slider control
Mar 08, 2015 Mar 08, 2015
Please ask me how to remove decimal value (.00) from slider control and add % (if possible) in after effects cs6.
73.6K
New Here , Mar 08, 2015 Mar 08, 2015
I guess you mean to animate text with a slider.
Add a slider control (expression controls) to your text layer, and then, add this expression into your Source text:
x=Math.floor(effect("Slider Control")("Slider"));
x+" %"
that's all
You can't.
Mylenium
Aug 17, 2021 Aug 17, 2021
You absolutely can
Precompose, then mask it out.
May 28, 2019 May 28, 2019
I'm already triggered
Mar 30, 2020 Mar 30, 2020
x+" %"
that's all
If you add this expression to an expression slider it will only return whole numbers.
math.round(value);
You will not be able to manually grab the slider control and make adjustments but you will be able to scrub through the values in the expression control and only end up with whole numbers.
If you want to add a % sign to the slider control you can't do that, but if you want to use the slider to drive a text layer then francoisg32545302 has given you an expression that will work. It will help us a lot if we knew what you were trying to accomplish.
Sep 05, 2016 Sep 05, 2016
Rick, you can always write the "Value" before the "math.round", then you can change the digits straight from the effects control.
something like this:
value = Math.round(effect("Slider Control")("Slider"))
Ido.
Mar 09, 2018 Mar 09, 2018
Hey thanks It worked for me...
Mar 16, 2021 Mar 16, 2021
Thaks @idoshor Thats work
Aug 03, 2022 Aug 03, 2022
now that's a value comment. Many thanks.
Mar 13, 2019 Mar 13, 2019
I use this and works too:
x+" "
I just delete the %
Nov 10, 2020 Nov 10, 2020
Cleaner way is this, and you can change the number from zero to set decimal places...
effect("Slider Control")("Slider").value.toFixed(0) + "%"
If you add an expression to the slider you lose the ability to use the slider in the effects control panel. If you use value.toFixed(0) or Math.round() in the property then the slider will still function in the effects control panel.
Sep 09, 2021 Sep 09, 2021
You don't lose the ability to use it if you create your expression around "value".
Jan 13, 2021 Jan 13, 2021
I resently use this code to create countdown
slider = effect("Slider Control")("Slider");
sec = Math.round( slider%60);
min = Math.floor(slider/60);
function addZero(n) {
if (n < 10) return "0" + n else return n;
addZero(min) + ":" + addZero(sec);
Change 60 to 59
