Topic properties is accessed and error code "The Parameter is
incorrect", hit OK, gets me to Properties but will not access
template and style sheet (lets me access one or the other.) I think
this happened when I accidently hit Generate PDF in the title bar
by mistake........at least I hit that and this what I got. I need
to get this error off so I can access style sheet and template at
same time. I get this error on ALL topics when I try to access
PROPERTIES.
Peter.....looked at site under snippets.......
said........"So just close your project, use Windows Explorer to
delete the PSS file" ....not following you, how do I do
that?
I just got the "parameter is incorrect" message under a
completely different set of circumstances. I opened my project and
clicked the PDF button at the top (accidentally -- meant to launch
the latest version of the help rather than generate PDF). Anyway,
PDF was generated successfully so I opened it. When I went back to
the RoboHelp window, I tried to right-click Printed Documentation
under Single Source (because I was going to tweak some settings)
and the dreaded "The parameter is incorrect." error popped up. I
cannot close the error box or do ANYTHING else in RoboHelp. I guess
I'm going to have to kill the process???? This is really ugly...
And I did see the "snipped" about deleting the PSS file. But
I assume I need to exit RoboHelp first?
