Good morning.
I am using RoboHelp 9 and I have been facing problems when I try to copy master pages to new blank projects.
Here's the thing: I have already created master pages including everything I consider as standard in my projects (that means, font style, font size, remarks and so on).
The only way I've got to apply those master pages was importing them from an existing Project.
However, when I copy those master page files in separate (.css and .htt) I am not able anymore to apply those styles in a new Project.
I would like to ask your help, because I do not want to have to open an existing file every time I need to copy and apply master pages.
Instead of it, I would like to save my standard master pages in a diferente folder, so that I could use them in any Project I want to.
I will be looking forward your reply.
Thanks in advance!
Camila Silva
I'm not entirely clear on the manual copy to a new project. If you place the .htt and .css in a separate directory, you can import them into your project from the Project Manager pod (or shared resources pod). What exactly is the workflow you're using?
You can create a master page and apply the css on it and then save it as .htt file(master page extension) and then import this master page into your new project. The styles and the formatting should be visible in the new file/project.
Thanks for your answer, but we have already tried it but it didn't work.
We're currently importing master pages from an existing project, because then it works.
Thanks for your help
