5 Replies Latest reply on Oct 29, 2007 11:35 PM by atta707
    How do I get date from my database without modification
    doug777
      How can I get the date from my database returned from RemoteObject exactly as it is in the database?
      It appears to get changed such that date in Flex = dbDate + ((serverTimezone*-1)+usersTimezone).
      The date returned by the CFC is correct (i.e. same as the date in the database).
        • 1. How do I get date from my database without modification
          atta707 Level 2
          Dates from RemoteObjects need to adjusted for time zone. Please search on following two keywords in the help:
          RemoteObject Date
          java.util.Calendar -> Date
          Dates are sent in the Coordinated Universal Time (UTC) time zone. Clients and servers must adjust time accordingly for time zones.
          java.util.Date -> Date
          Dates are sent in the UTC time zone. Clients and servers must adjust time accordingly for time zones.
          A quick fix, of course, would be if you sent a formatted string instead of the Date object.
          HTH.
          ATTA
          • 2. Re: How do I get date from my database without modification
            doug777 Level 1
            This surely is a serious fundamental fault in Flex.
            It can't be the underlying java to blame because the dates returned from the database show up correctly in my ColdFusion programs. They are only wrong in Flex.
            Flex seems to have been developed without any thought being given to timezone invariant date/time objects.
            An example of a timezone invariant date/time object is when I say for example, 'I started work on Monday October 29 at 9am, and finished at 5pm.'
            If I said this to someone in a timezone 5 hours ahead of me, it would be wrong to say: 'I started work on Monday October 29 at 2pm, and finished at 10pm.' It wouldn't matter what timezone I was in on Oct 29 or what timezone the listener was in, the fact is that the first example is always correct and the second example is always wrong.
            All my date/time objects in the database are timezone invariant. It doesn't matter what timezone the server is in or what timezone the user is in.
            So how can I fix it?
            The user could have picked up a server in any timezone. The user could be in any timezone.
            Many of my RemoteObject calls return large complex objects which may or may not include date objects. Do I really have to pick them apart, find the dates, find this server's timezone and user's timezone, or as you say get them in the SQL and convert them to strings, then find them and convert them back to dates in Flex, in order to reverse the incorrect operation that Flex makes? The structure of each returned object is probably different, so I will have to write a different routine for every single RemoteObject call that might return with a date.
            If alternatively I save the date as UTC, how can the client work out what timezone it was saved in to convert it back to the correct time?
            Surely there is some other solution than these.
            What is Adobe's view?
            Doug
            • 3. Re: How do I get date from my database without modification
              atta707 Level 2
              +1.
              This is actually bad choice!
              • 4. Re: How do I get date from my database without modification
                doug777 Level 1
                Do you mean Flex is a bad choice if you're in the airline industry, or are a railway operator, bus company, hotel, theatre, cinema etc., who all need timezone invariant date/times.
                I'm now hoping the website I used to book tickets to go and see Lord of the Rings at a theatre in London wasn't developed with Flex or I'll be arriving for the performance 8 hours too late.
                There must be a solution to this, but what is it??
                Doug
                • 5. Re: How do I get date from my database without modification
                  atta707 Level 2
                  I'm sorry if I wasn't clear in my previous message. I actually concurred with your remarks on why Flex should handle timezone invariant timestamps.
                  Now that I think about it, it makes more sense that there should be a way to override this 'bad default'
                  What? I'm clueless. Maybe some from Adobe can shed some light on it.
                  ATTA
