Thanks Peter, Colum, and Harvey.
Finially, I got this problem sovled. :))
First, I used your ideas to find the topic with problem. It
took me 2 hours. Not too bad.
Then I scaned in that topic and digged out the sentences that
caused the problem in the Truecode view:
<meta name=MS-HKWD content="execution mode">
<meta name=MS-HKWD content="trig">
I removed above sentences, the problem is gone. I can use the
command line compiler now.
I don't know how and when these keywords were added into the
project. This project was owned to someone else before. I re-added
those keywods in the Index tab. Everything goes well. So there is
no impact on my project.
However, I think the command line compiler should be able to
handle this kind of "meta" sentence if the compiler in the GUI can
do.
Can I think this is a defect of RH6 or it is designed like
this, or it is a defect of my project?
AGsMM
