1
how do I make audio clips loop in premiere or elswhere
Feb 23, 2013 Feb 23, 2013
HOW DO I MAKE AUDIO CLIPS LOOP IN PREMIERE OR ELSWHERE?
93.1K
Explorer , Mar 19, 2016 Mar 19, 2016
None of these answers are correct.
My brother found this thread, looking for help, and left in frustration, asking me for the answer instead.
Kevin-Monahan's answer is only half-complete.
Here's the full answer:
To loop a video or audio clip on the timeline, right click it and select "Nest..."
Name the nest whatever you like.
Now, double click the nested clip you just created. This will enter the nested sequence.
NOW, you can select the clip, copy it, and paste it multiple times. (Just keep hitting CTR
You can do it in AE by just setting the number of loops in the Footage Interpretation window. Making a seamless audio loop in Audition is also a simple matter. Just looping audio by repeating the track will not usually work to create a seamless audio bed. What are you trying to do?
Mar 04, 2013 Mar 04, 2013
Thanks RickI use some long clips of horse riding and the relevant instructions involved in equine assisted therapy. Most of the audio I have is short, so I wanted to make longer tracks by looping.Ray Holland (equinoterapia)
Adobe Employee ,
In the Premiere Pro timeline, just copy/paste the section you want to loop into the Timeline. Repeat the process for as many loops as you need.
Engaged ,
Nov 28, 2013 Nov 28, 2013
missing this option in this app.
Engaged ,
Mar 10, 2015 Mar 10, 2015
very "practical" solution and such fresh ...
Mar 11, 2015 Mar 11, 2015
That solution of cut and paste is not actually a loop.
Loops are endless by definition.
Copies  are finite. ie they will end when the copies end.
Maybe you were not wanting a "loop"..but a repeat of a clip.
Engaged ,
My comment that answers "Kevin-Monahan"
OK
There is no way to LOOP a sequence by exporting it into a movie file.
Its logic ...because a Sequence is finite.
Looping an output can only be done automatically by authoring a DVD (AFAIK).
Otherwise..its up to the "player"...but that not automatically looped and requires viewer input. (Press Loop.)
BTW - the OP got the answer to his question from Kevin.  He was not after a "loop".
Engaged ,
Mar 13, 2015 Mar 13, 2015
Jul 26, 2015 Jul 26, 2015
but what if my section is just a few seconds long and I don't want to copy and paste it about 300x times? Is there really no other way?
Contributor ,
well, copy the clip.
Then copy the first 2 clips.
Then copy the first 4 clips
It'll be much less then 300x times
Oh man ... why can't they just handle it like Sony Vegas. Where I simply drag the footage as long as I want and it is automatically getting repeated when I make it longer than the source ...
Sep 23, 2015 Sep 23, 2015
I believe what is looking for is something similar to what you can do in After Effects.
In the "interpret footage" settings of a clip you can set it to "loop" or "cycle" as many times as you want.
Much easier than copy and pasting multiple times (30 or 300). It would be a very useful function to have in Premiere too.
Example - I have a short beep sound 8 frames long,Loading this multiple times into the time line is going to be a little "messy", so I'll load it in Audition and create my loop there.
Better if I could do it in Premiere, instead of needing another step and application.
Hi bartstevens
Many thanks for the information.
Ray Holland
Aug 12, 2019 Aug 12, 2019
horrible answer. The option exists correctly in After Effects. How hard would it be to make the identical option in Premiere?
Oct 25, 2015 Oct 25, 2015
If you want to loop audio or video in the timeline, you first need to set in and out points for your clip (right click in at the top of the time line and Mark In/Mark Out, or use controls in playback window).  Once you have done this, you then have to turn on looping.  I have found that in the last few version of Premiere, the loop function keeps moving.
As of right now (Premiere Pro CC October 2015), you need to go to your program/playback monitor, and on the bottom right hand side you will see a plus button.  Hit this to bring up options for other buttons the playback controls can display.  One of them is a loop function. Drag this to the bottom of the monitor window, turn it on, and then your clip will loop infinitely between the markers.  This is great for adjusting applied effects on the fly.
In older versions of Premiere, you'll find the looping in the options menu in the upper right hand corner of the playback monitor.  The options menu is a little button...easy to miss.
Another helpful key combo is Shift+K which resets and plays your audio from wherever you first clicked in the timeline.  This one is very helpful for audio too.
Hope that helps.  Took me forever to find!
Jan 24, 2022 Jan 24, 2022
GREAT answer this works awesome for looping a clip or any section in PR. Audio/Video. In some apps you just press Ctrl+L on a clip and the clip loops forever until you press stop. this has a similar result with a few more key strokes/mouse moves.
NOW, you can select the clip, copy it, and paste it multiple times. (Just keep hitting CTRL V, and the playhead advances forward automatically to place the next clip.)
Return to the main sequence.
Now, you can use the selection tool to extend that nest as much or as little as you like.
This is a far superior method, because a nested sequence is a SINGLE CLIP that can be resized, given effects, moved, lengthened, and shortened very easily.
Adobe Employee ,
Mar 25, 2016 Mar 25, 2016
Hi TTTipsy,
Thanks for the response. I marked your answer as the correct one now since it's better.
Kevin
Engaged ,
Sep 14, 2016 Sep 14, 2016
It is about time PR adds the function AE has for looping a single clip the desired number of times by right clicking it in project panel.
