Hi all
Perhaps I might offer some insight here. I see that Colum
correctly indicated the basic steps, but there seems to be a bit of
confusion. I think I may know why.
Here are my own basic steps.
1. Create See Also keywords
2. Assign them to topics
3. Insert See Also controls that point to the keywords
Here is where you are probably confused. How exactly to
define and assign the See Also keywords. You should be doing this
using the Index designer. So click the Index tab (hoping here you
are using version 6 or older-please advise if you are using 7, as
the process may be a tad different and need further explanation)
From the Index tab, look at the top of the Index designer and
you see a drop-down that you click and have two choices. Index and
See Also. If you choose See Also, the main part of the Index
designer changes. Once there, you add See Also keywords. You then
display the Topic list on the right side and drag desired topics
from the list on the right, into the Topics For area at the bottom
of the See Also designer.
After you do this, your See Also control insertion should be
pretty straightforward.
Hopefully this helps... Rick
