I have tried to install from SCCM and through elevated (administrator) command line without success.
Install commands I have tried are:
All have failed. I just realized that Windows 8.1 IE comes with an older version of flash. How do I get it to update?
Below is the FlashInstall log, but I'm not able to figure out the issue. Any help would be appreciated.
=O====== M/16.0.0.235 2015-03-09+19-17-50.143 ========
0000 00000010 "C:\WINDOWS\TEMP\{10F1E587-3662-4593-8611-D2D22C72873E}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 2
0001
0002
0003
0004
0005 00000018
0006
0007
0008 00000013
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_16_0_0_235_ActiveX.exe
0010 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_16_0_0_235_ActiveX.dll
0011 00000023 C:\WINDOWS\system32\Macromed\Flash\activex.vch
0012
0013 00000018
0014
=X====== M/16.0.0.235 2015-03-09+19-17-52.488 ========
=O====== M/16.0.0.305 2015-03-11+13-56-11.049 ========
0000 00000010 "C:\Users\WGRAM\AppData\Local\Temp\{4492E183-B1F2-4CD5-B4F7-72B23779DEA8}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 2
0001
0002
0003
0004
0005 00000018
0006
0007
0008
0009 00000013
0010 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_16_0_0_305_ActiveX.exe
0011 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_16_0_0_305_ActiveX.dll
0012 00000023 C:\WINDOWS\system32\Macromed\Flash\activex.vch
0013
0014 00000018
0015
=X====== M/16.0.0.305 2015-03-11+13-56-12.649 ========
=O====== M/16.0.0.305 2015-03-11+14-17-12.916 ========
0000 00000010 "C:\Users\WGRAM\AppData\Local\Temp\{FDAEAD86-D68B-4974-9349-595378076688}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001
0002
0003
0004
0005 00000018
0006
0007
0008
0009 00000013
0013
0014 00000018
0015
=X====== M/16.0.0.305 2015-03-11+14-17-14.308 ========
Any help would be appreciated,
Wendell
You need to update it with Windows Update. You can also go to: Flash Player Issues | Windows 8
and at the bottom grab the KB, however I've had much better luck using Windows update than I have with the KB alone.
Thank you Geeks2You. I will try this and post the results.
Installed the Windows8.1-KB3044132-x64.msu
This updated the Flash Player, so i'm going to try pushing it out now via SCCM.
Thanks again.
