Context-sensitive WebHelp not working
Guest
Jun 18, 2012 Jun 18, 2012
I need to create a context-sensitive WebHelp system for a web application. I have the topics and the map file created, and the developer has coded the call to the help topic as indicated in http://www.grainge.org/pages/authoring/calling_webhelp/using_map_ids.htm. It works correctly if I double-click the help system's start page to open it, but when it is called from within IE, all pages in the application call the main help topic.
The help call in the code appears to be correct, but there is obviously something missing, either on my end (help author) or on his end (developer).
I'd appreciate any help anyone can give me.
P.S., I'm using RoboHelp 9.
791
What do you mean by 'when it is called from withing IE'? If your application calls the help correctly, it seems you've correctly used the CSH API. But for calling the help from another web page, you will also need to implement the CSH call.
Greet,
Willam
Guest
Jun 19, 2012 Jun 19, 2012
What I mean is, when I enter the path to the help system in Internet Explorer's address (URL) text box, that's when all pages go to the main topic.
What needs to be done to implement the CSH call?
Mar 11, 2015 Mar 11, 2015
jmmpc - did you ever get an answer to this or solve it? I think I'm having the same issues you had.
Mar 12, 2015 Mar 12, 2015
Did you select the map files in your output settings?
I "tried" to - I am using RoboHelp 10, and in RoboHelp for Word, I can see the map files, the topics are assigned map ids, but when I generate WebHelp, the output does not contain a single .h or .hh file.  I am going to import this project into RoboHTML and see what happens.  If anyone has any suggestions on how to get RoboHelp10 to actually produce output that contains .h files, please let me know!
Claudia
The .h file will not be present in your output. In your output, the map information will be an integral part.
In your SSL settings, on the Content page, you have to select which .h files you want to use for context sensitivity.
Thank you, so this means it *should* be working.  Maybe I am testing this wrong.
Question 1: Can I test this manually by typing a URL + parameters into IE?
This is what I am trying to do:
I have a Apache Tomcat server running on http://localhost:8080
My underlying directory structure for the Tomcat server looks like this:
C:\CATALINA_HOME\webapps\helpsys\
my help folders\files are in the helpsys folder
I am trying to type in strings that look like these:
sorry - need to get the strings
the strings are awaiting moderator approval (sigh)
Hi Claudia
That sounds like a forum thing? I'm a forum moderator and I'm not seeing anything that would indicate this and I'm seeing the strings.
Can you please expound? Did you see a message or what?
Cheers... Rick
sent you a message because this Reply window isn't posting anything!
While these strings DO open the help system (nav pane, content pane, TOC, search & index tabs are all there) - I cannot figure out how to get the content of the topic that was assigned the context ID 1000180 to be displayed.
http://localhost:8080/helpsys/index.htm#context=1000180,withnavpane=false
opens to welcome, not window with 1000180 map ID
http://localhost:8080/helpsys/index.htm#<id=1000180>>>newwnd=true
opens to welcome in sep window, blank tab underneath
So, how should I be testing these calls to a specific help topic?
thanks!
RoboHelp Documentation
Download Adobe RoboHelp
