component calling methods on another component
Oct 30, 2007 Oct 30, 2007
I have 2 components: Repository, and Document. A repository has an array of documents in variables scope. In each component I use the init() method to return an instance of the object. When a repository object is inited it generates a query of the documents that it contains, and loops through that, calling document.init() on each one and adding the resulting document object to the array.
When I init() a repository and use CFDUMP to view its documents array, I get an array of the correct length containing document objects. However, when I try to loop through the array and call a method like getTitle() on each document, I get empty strings. When I init() a document on its own, getTitle() works fine. Is there something basic that I'm forgetting here?
Let me know if you need to see the more code.
Don Zacharias
Sacramento, CA
Advanced techniques
968
Community Beginner , Oct 31, 2007 Oct 31, 2007
OMG I just nailed it. On the front end template, I tried using createObject each time through the loop of documents, and then setting the resulting empty document object to the document in the array. That worked. Thanks everybody!
I always use cfobject or createobject to return an instance of the cfc. Have you considered trying that?
Yeah I am using the pattern of an init() method that returns an instance of itself, so it can be chained to the createObject call. It seems to append an object, but I can't figure out how to work with that object. Any ideas? Thanks!!
Guide ,
So where are you setting the other document properties like "Title"?
In the Document's init method, those properties are pulled from the database and set in variables scope. Then I use getTitle() etc to pull it back out.
And yeah those work fine when I'm just initing a document by itself, it's just when I am trying to init a bunch of documents in the repository's init method, and then call methods on those documents.
I feel like I'm missing something very basic here... Thanks!
Guide ,
quote:
I'm not sure how that's different than what you were doing before 😉 but I'm glad its working for you.
<cfloop query="qDocuments">
<!--- create empty document object --->
<cfset document = createObject("component","Document").init(qDocuments.id)>
<!--- add empty document to array --->
<cfset arrayAppend(variables.documents,document)>
</cfloop>
In the Repository's init() method:
</cfloop>
In the front end
<!--- show documents for this repository --->
<cfset arr_documents = repository.getDocuments()>
<cfloop from="1" to="#arrayLen(arr_documents)#" index="i">
<cfset doc = createObject("component","/docmanager_v2/components/Document")>
<cfset doc = arr_documents[ i ]>
<cfoutput>Title: #doc.getTitle()#, Summary: #doc.getSummary()#, Keywords: #doc.getKeywords()#<br></cfoutput>
</cfloop>
Now I'm doing createObject twice but I guess that makes sense... I wish I knew the principle at work here though...
Guide ,
dzacharias,
Nevermind. I see from your post you are creating new instances.
Guide ,
You shouldn't have to create the objects twice. I'm not even sure why that would work any differently, since in the end you're using the object from the array anyway.
<!--- the variable "doc" is overwritten in the next line --->
Also, are you properly VAR'ing your function local variables?
Actually you're right... I don't know why but I must not have tried it that way. Each time through the array I just copy the array element to a new variable and access the document methods through that variable and it works fine. Thanks again!
Guide ,
Okay. Remove the second createObject() then. No point incurring the expense of createObject() if its not needed ;-)
IIRC its just a reference to the array element at that index, but yes that works 🙂
Documentation
