Responsive HTML 5 SSL without web address bar
Mar 12, 2015 Mar 12, 2015
Hi there.
Can anyone help me with removing the web address bar from the responsive HTML 5 SSL.
On the left is the default HTML 5 and on the right is the Robohelp layout. I need my help file to be a stand alone file as per the Adobe file with no web address bar.
Many thanks
259
You want to be looking at Context Sensitive Help (CSH) calls – BTW, the RH help is a custom skin that only Adobe has
Thanks Jeff, can the address bar simply not just be turned off as an option before I generate my SSL?
Hi Greg
As Jeff said, there are precious few ways to make this happen. The help created via the SSL simply opens in a browser. There isn't really a way to generically make it alter behavior of the browser. But if it's context sensitive, you might define a "Window" that would be used by the context sensitive call. And if you do that, you have some options over what gets included as the call references a specific named window with specific characteristics (such as the Address bar)
Hopefully Willam will pop in to advise on this. I might assume the same holds true for Responsive outputs. But I'm not 100% certain.
Cheers... Rick
Mar 18, 2015 Mar 18, 2015
As Rick mentions, the address bar is a browser thing and you can't just turn it off. The only way to do that is to open the help in a popup. (That's what CSH help does to hide the address bar so you get this solution for free with the CSH API.)
It also holds true for Responsive.
RoboHelp Documentation
Download Adobe RoboHelp
