I have a bit of a problem with my chm file in that about 6 of
the many drop-down hotspots aren't opening when the user clicks on
them. I took a look at the True Code to see what was happening and
I can't see any difference between the ones that work and those
that don't. Is there a maximum number of DHTML items you can
include in a chm file? Or can anybody think of what else might be
going on here?
I've seen this when the ID on the hyperlink and hidden div
don't match. Viewing the code, check that "x-use-popup" code
matches the id on the hidden div.
It will looks something like "a class=dropspot
x-use-popup=#POPUP320846813" and "div class=x-popup-text
id=POPUP320846813"
The other thing to check is that there aren't multiple divs
with the same number.
I've found RH6 sometimes gets confused if you have something
like:
Dropspot 1
Dropspot 2
Dropspot 3
And have at some point had them all in one paragraph and
pressed Enter to separate them. That gives some really funky
results.
Have you tried recreating the dropdowns? We ran into a
situation much like Amebr's and redoing the dropdowns typically
fixed the problem. If that works, then fixing half a dozen
instances shouldn't be too bad.
I found the same problem, though after searching long and
hard, what I realised is that the dropdown's style is suddenly set
to "none". As soon as I changed it to normal or heading 1 or
whatever else, deleted a space or 2, it worked.
