hi,
i have a pdf form made by adobe livecycle designer. here there r 2 fields. say one field A and anothe is B . i want to populate info in field b which will depend on value of A. IF i put 4 in A then B will 17., if A 5 B 21 .... etc. can u pls help to make such tye of code?
thanks
Ali
Total Likes
I am limited with Livecycle but I am going to try to help you as best I can. This solution may be helpful.
For field A you will need a script. JavaScript. On the change event. It should be similar to the one below.
if
Text.Field.A.rawValue == 4
then
Text.FIeld.B.rawValue == 17
elseif
Text.Field.A.rawValue == 5
then
Text.Field.B.rawValue ==21
endif
This code should get you on the right track. You can repeat sections of this code to allow for more bindings. Please forgive any scripting mistakes. As I said, this is only meant to help get you on the right track.
Total Likes
