i want to install my photoshop 5.0 limited edition but the pc displays i should check if it is a 32 or 64 bit application. i changed my windows os from xp to win7 64 bit (i think that is the problem) how can i install and run my photoshop 5.0 le on this system?
that's no longer available via adobe and if you buy it from someone else you'll likely have problems running it. i think it's compatible with win 98 but i don't know if that's available to you using compatibility mode.
thank you! i tried xp and win98 compatability mode before without any result =(
sad that adobe does not support such problems.
you're welcome.
i think you can (legally) use ps cs2. read the verbiage to make sure, Error: Activation Server Unavailable | CS2, Acrobat 7, Audition 3
Kglad Creative Suite 2 is only applicable to individuals affected by the activation server shut down. A complete list of affected software titles can be found at Activation server shut down for Creative Suite 2, Acrobat 7, and Macromedia products.
