1
how to fix Error found: E_ACT_NOT_READY?, how to fix Error found: E_ACT_NOT_READY?, how to fix Error found: E_ACT_NOT_READY?
Guest
Mar 07, 2015 Mar 07, 2015
E_ACT_NOT_READY
6.6K
Adobe Employee ,
Mar 08, 2015 Mar 08, 2015
For this problem, you need to deauthorize and authorize ADE again.
Launch ADE
Help -> Erase authorization.
ADE will be deauhorized.
Now again AUTHORIZE ADE
Help-> authorize computer.
Error will be fixed !!
Mar 16, 2015 Mar 16, 2015
Hi!
I am using a Mac. I get this same error.  HOWEVER, your directions DO NOT work.  When I go to "Erase Authorization" I get this message: "Unable to Erase Authorization. Please try after some time."
I have tried several things: completely uninstalled Digital Editions and then Re-installed. Shut down computer. These steps are not working.
How can I erase authorization if it wont let me?
Adobe Employee ,
If due to some reason, you are unable to deauthorize ADE, follow the below steps:
Mac: Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
ADE will be deauthorized now.
Now Authorize ADE again.
Hi! Thank you So much for the fast response.
I have searched my entire mac and there is no file with the name activation.dat.
There is also NO Library folder under my Users...
I do have about 100 other files with the .dat extension, but absolutely NONE that are called activation.dat
Adobe Employee ,
Ok, try the following way to access activation.dat:
1. Go-> Go to folder.
Go to folder dialog will appear.
2. Type   ~/Library/Application Support/Adobe/Digital Editions
Hope this works !!
Jan 09, 2017 Jan 09, 2017
This worked great. Found .dat file this way. Trashed it then re-authorized. And voila....!
May 21, 2019 May 21, 2019
I found this answer to work for a Mac:
"A few months ago I changed my Adobe ID and password. Fast forward to now and I'm having the same prob as everyone else. Here's what worked for me:
1. Go to the Finder menu.
2. Hold down the Option key and select Go. This reveals the hidden user library.
3. Select Library.
4. Go to Application Support -> Adobe -> Digital Editions and delete the file named “activation.dat”
5. Now one can reauthorize Adobe Digital Editions."
Sep 08, 2015 Sep 08, 2015
I tried everything that everyone has suggested (including trashing ADE 4.0 and installing 3.0) and ran into the same problems.  Then I spent two hours chatting with an Adobe chat room person who finally gave up on me because my computer skills are those of someone born during World War II.  That is probably because I was born during World War II. Then based on I don't know what I de-authorized my computer (not the de-authorize ADE path that has been suggested) and then re-authorized it, and problem solved.  I have nothing more to add.
Sep 11, 2015 Sep 11, 2015
I've the same problem and I also do not have a folder "..Digital Edition". So I cannot put any file into trash. I also try to chat with Adobe an I got the answer that I have to ask the community for that.
Digital Edition is not in the chat support. I really angry. What a support. No one can help and you can not load any book on your computer.
Jan 29, 2016 Jan 29, 2016
Hope this helps.
3. Select Library.
thank you very much for supplying the fix to my Mac - unable to deauthorise-
Mar 21, 2016 Mar 21, 2016
Thank you! This fixed my problem!
NOTE: After following those steps, it still said my computer was authorized. I closed ADE and relaunched and upon relaunch, it gave me the option to authorize.
Sep 16, 2018 Sep 16, 2018
This helped me and fixed me thank you for taking the time to show me the way to solving this problem
Jun 01, 2016 Jun 01, 2016
I have the E_ACT_NOT_READY on Win10.
I used Zinstall Pro to move all my applications from my crashed PC's drives to my new laptop. All the other program work except Adobe Digital Edition won't load the only book I purchased - gives the error above. It will load "Getting Started" book.
The options I have under "Help" are
(  i) Authorization Information
( ii)  Adobe Digital Editions Help - which is useless as they didn't help but sent me here
(iii) Authorize computer  --  which won't show anything or turned off.
"Authorization Information" say my laptop is "authorized".
What should I do?
Jun 02, 2016 Jun 02, 2016
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Jun 06, 2016 Jun 06, 2016
Nanaky, thank you so much. IT WORKED!
Jun 23, 2016 Jun 23, 2016
You are welcome.
Oct 23, 2022 Oct 23, 2022
Muito obrigado! Ajudou muito.
Mar 19, 2017 Mar 19, 2017
If I reauthorize my ADE, will I lose all the books I have saved there?  Is there any way I can back them up before I reauthorize?  -- All of you who reauthorized, did you lose any saved items?  Eleanor
Apr 16, 2018 Apr 16, 2018
Can someone help me with my adobe editions version 4.5.8? I'm on a Mac. When I try and drop a book from the library into Adobe Editions I get the following message:
E_ACT_NOT_READY
I am unable to Unauthorize the account, I've tried and it won't allow me to do it. What now?
May 22, 2019 May 22, 2019
Hi I have deauthorized and re authorized also but still I am unable to open acsm file on my mac
Oct 14, 2023 Oct 14, 2023
Pouvez-vous faire en sorte que je puisse utiliser "Adobe Digital Éditions 4.5.1.2"?
Merci pour votre aide,
Rolland Grenier
