Hi
I'm having trouble creating and viewing .chm files with the new updated version of RH11.
I updated this morning to 11.0.4.291 and now I cannot create .chm files. When it does create the file I am presented with a dialog box claiming "Cannot open the file: mk:@MSITStore:C\<File Path>" when i try to open it and when i try and delete the file it tells me the RH is using it.
Any ideas on this?
Hi there
I'm guessing this happens with *ANY* CHM file you create?
Is it only happening when you click the View button after the CHM compiles? Or is it also happening when you locate the CHM and double-click it from inside Windows Explorer?
You might try downloading and running MJ's diagnostics. That may correct things.
Click here to visit the download page
Cheers... Rick
Hi Rick,
It happens when I run any CHM file in window explorer. I uninstalled and rolled my version back to 235 which seemed to fixed the issue for most of the CHM files except 1. So I will try MJ's tool and report back. Has this issue cropped up before?
Cheers
Greg
