Prior to reinstall windows stood Google Chrome and Flash Player worked . After reinstalling, Google Chrome is not installed. Install Mozilla Firefox, but I can not install Flash Player. (Error: common installation error)
Hi Илья,
Please provide the FlashInstall.log file saved at C:\Windows\System32\Macromed\Flash using the instructions here, How to share a document. If you have a 64-bit OS, also provide the log file saved at C:\Windows\SysWOW64\Macromed\Flash.
Thank you.
Maria
Please, I hope it helps you find a mistake
Thank you , Maria
According to the log file, the installer file is missing some required components. Pease provide the following to help us identify the root cause:
After obtaining the above information, please do the following:
If you get an error during any of these steps, please take a screenshot and post the screenshot, indicating at which step the error was returned.
Maria
From official site - Установка Adobe Flash Player для всех версий
File name - install_flashplayer17x32_mssd_aaa_aih (last try)
- install_flash_player
To solve the problem, I tried to install the beta version of Flash Player. I downloaded 2 uninstaller. When trying to remove the flash player in both cases did not work and antivirus finds a virus. To remove all the same flash I disabled antivirus and removed player
After restarting the computer, I started to install the player. Anti again showed the presence of the virus. Then I turned it off and tried again. The installation was successful.
Conclusion - the whole thing in anti-virus? why he finds viruses?
Thank you very much Maria
Hi kykez,
I don't know why your anti-virus software is detecting a virus in the installers. We do check them for viruses before releasing them. Can you translate what your anti-virus software is finding?
After viewing the log file you provided it appears that the installer is not finding a required component. The online installer, downloaded from get.adobe.com/flashplayer is a shim installer that then downloads and installs Flash Player silently in the background. Since you were using this installer and it failed to find a required component I suspect there was some failure in the download process.
As for installing a beta, while you most certainly can do that, since it is beta quality software there's the possibility that you will encounter viewing and performance issues. Beta installers are geared to enterprise customers and Flash developers.
I recommend you use the offline installer, using the instructions I provided in my previous comment (on 17-March).
Maria
my antivirus says that he discovered and neutralized the following viruses, thats all
