Hi there ... I've packaged up Presetnter 10 32-bit using the Creative Cloud Packager, however upon attempting an install it is failing with an error 1603 which seems to be related to a custom action in the MSI.
CustomAction CADeploy returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (98:8C) [12:26:51:858]: User policy value 'DisableRollback' is 0
MSI (s) (98:8C) [12:26:51:858]: Machine policy value 'DisableRollback' is 0
Action ended 12:26:51: InstallFinalize. Return value 3.
Ken
Please make sure that you are following the correct process while creating a package or deploying a package.
Instructions for creating Presenter 10 package for
...Copy link to clipboard
Thank you for this link, while it provides all the info, the answer below does it all in this thread, so I marked that one as correct in case the link you provided is ever unavailable. The screenshots in your answer make it easier for people to follow. Thank you for your response.
Instructions for creating Presenter 10 package for 32-bit OS and 32-bit PowerPoint or for 64-bit OS and 64-bit PowerPoint:
Instructions for creating Presenter 10 package for 64-bit OS and 32-bit PowerPoint:
Deployment Instructions:
On your machine you have to open Command Prompt, Right click on it and select Run as administrator. In Command Prompt you have to go to the exact path where Presenter package folder is placed and go inside build folder.
Once you are in build folder location in Command Prompt then type the command :- msiexec.exe /i name of the package.msi /quiet and press enter.
After then please open Task manager , In process tab you will see msiexec processes are running and It will install/deploy the Presenter 10 Package silently on your machine.
Rajeev.
