Problem with Flex Messaging using JMS
Avatar
Level 1
Hi Friends,
I have started working on flex recently and got problem while
implementing Flex Chat application using JMS adaptor. I was able to
successed making it work with Flex Action Script, but I need have
my chat application with JMS. Here I am posting the details about
how I have done the chat application for JMS.
I am using Tomcat 5.5.25, Flex 2 and ActiveMQ 4.4 M4.
my WEB-INF/flex/messaging-config.xml with destination as
<adapters>
<adapter-definition id="jms"
class="flex.messaging.services.messaging.adapters.JMSAdapter"
default="true"/>
</adapters>
<destination id="chat-topic-jms">
<properties>
<server>
<durable>false</durable>
<durable-store-manager>flex.messaging.durability.FileStoreManager</durable-store-manager>
</server>
<jms>
<destination-type>Topic</destination-type>
<message-type>javax.jms.ObjectMessage</message-type>
<connection-factory>topicConnectionFactory</connection-factory>
<destination-jndi-name>FlexChatTopic</destination-jndi-name>
<durable-consumers>false</durable-consumers>
<delivery-mode>NON_PERSISTENT</delivery-mode>
<message-priority>DEFAULT_PRIORITY</message-priority>
<acknowledge-mode>AUTO_ACKNOWLEDGE</acknowledge-mode>
<transacted-sessions>false</transacted-sessions>
<initial-context-environment>
<property>
<name>java.naming.factory.initial</name>
<value>org.apache.activemq.jndi.ActiveMQInitialContextFactory</value>
</property>
<property>
<name>java.naming.provider.url</name>
<value>tcp://localhost:61616</value>
</property>
</initial-context-environment>
</jms>
</properties>
<channels>
<channel ref="my-rtmp"/>
</channels>
<adapter ref="jms"/>
</destination>
my WEB-INF/classes/jndi.properties file
java.naming.factory.initial =
# use the following property to configure the default
connector
java.naming.provider.url = tcp://localhost:61616
# use the following property to specify a class path resource
or URL
# used to configure an embedded broker using the XML
configuration file
#brokerXmlConfig = file:src/conf/sample-conf/default.xml
# use the following property to specify the JNDI name the
connection factory
# should appear as.
connectionFactoryNames = connectionFactory,
queueConnectionFactory, topicConnectionFactory
# register some queues in JNDI using the form
# queue.[jndiName] = [physicalName]
# queue.MyQueue = example.MyQueue
# register some topics in JNDI using the form
# topic.[jndiName] = [physicalName]
# topic.MyTopic = example.MyTopic
topic.FlexChatTopic = chat.Topic
in my web.xml file I have added
<listener>
<listener-class>com.silverisland.servlet.listener.ActiveMQBrokerStartListener</listener-class>
</listener>
finally my mxml file
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"
creationComplete="consumer.subscribe()">
<mx:Script>
<![CDATA[
import mx.messaging.messages.AsyncMessage;
import mx.messaging.messages.IMessage;
import mx.controls.Alert;
private function send():void
var message:IMessage = new AsyncMessage();
Alert.show("msg dst >> "+message.toString());
message.body.chatMessage = msg.text;
producer.send(message);
msg.text = "";
private function messageHandler(message:IMessage):void
Alert.show("msg recived >> "+log.text);
log.text += message.body.chatMessage + "\n";
</mx:Script>
<mx:Producer id="producer"
destination="chat-topic-jms"/>
<mx:Consumer id="consumer" destination="chat-topic-jms"
message="messageHandler(event.message)"/>
<mx:Panel title="Chat" width="100%" height="100%">
<mx:TextArea id="log" width="100%" height="100%"/>
<mx:ControlBar>
<mx:TextInput id="msg" width="100%" enter="send()"/>
<mx:Button label="Send" click="send()"/>
</mx:ControlBar>
</mx:Panel>
</mx:Application>
Please help me.
Thanks in advance
Kumar
Avatar
Former Community Member
What exactly is the problem? Turn on debug logging on the
server and let us know if you see any exceptions/errors.
Avatar
Level 1
Hi Mete Atamel,
The problem here is I am not able to send the message to the
server. There is no error / exception raised.
The same code is working fine when I was using "Flex
Messaging service" with the following changes.
my
<adapter-definition id="actionscript"
class="flex.messaging.services.messaging.adapters.ActionScriptAdapter"
default="true" />
<properties>
<network>
<session-timeout>0</session-timeout>
</network>
<server>
<max-cache-size>1000</max-cache-size>
<message-time-to-live>0</message-time-to-live>
</server>
</properties>
<channels>
</channels>
</destination>
But when I changed the same code to make it work for JMS
adapter, it is not even sending the message to the server itself. I
was not able to understand the actual problem. Can u please tell me
where I was going wrong.
Thanks in advance.
Kumar
Avatar
It's hard to tell what might be wrong. You should turn on
server side debug logging on. Look into services-config.xml,
there's a logging section. Make sure the level is set to "Debug",
run your test again and see what server side logging you get. If
you cannot send messages, there should be more info in the debug
log for why that is happening.
Avatar
Level 1
Did you ever get this working?  I'm attempting to do a similar thing with Jrun4 -
There is a good article here that might help as your configuration is similar.
