SOLVED
Destination Problem
Avatar
Level 1
In my project I want to use a RemoteObject instance to
retrieve a Java object. I think I've got all the files in the right
places, but still I get this error:
[RPC Fault faultString="[MessagingError message='The
MessageAgent's destination must be set to send messages.']"
faultCode="InvokeFailed" faultDetail="Couldn't establish a
connection to ''"]
at mx.rpc::AbstractInvoker/
http://www.adobe.com/2006/flex/mx/internal::invoke()
at mx.rpc.remoting.mxml::Operation/
at mx.rpc.remoting::Operation/send()
at Function/
http://adobe.com/AS3/2006/builtin::apply()
at mx.rpc.remoting.mxml::Operation/send()
at Function/
at mx.rpc::AbstractService/
http://www.adobe.com/2006/actionscript/flash/proxy::callProperty()
at Medewerkers/request()
at Medewerkers/___Application1_creationComplete()
at
flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
My RemoteObject code looks like this:
<mx:RemoteObject id="MedewerkerService"
source="com.atosorigin.services.MedewerkerService">
<mx:method name="getMedewerkers"
result="{resultHandler(event)}" />
</mx:RemoteObject>
The return object is an array of Medewerker, which I retrieve
like this:
public function resultHandler(event:ResultEvent):void {
medewerkers = event.result as ArrayCollection;
I use the following Services-config.xml:
<services-config>
<services>
<service-include file-path="remoting-config.xml" />
</services>
<channels>
<channel-definition id="my-graniteamf"
class="mx.messaging.channels.AMFChannel">
<endpoint uri="
http://{server.name}:{server.port}/{context.root}/graniteamf/amf"
class="flex.messaging.endpoints.AMFEndpoint" />
</channel-definition>
</channels>
</services-config>
With a remoting-config.xml:
<service id="remoting-service"
class="flex.messaging.services.RemotingService">
<adapters>
<adapter-definition id="java-object"
class="flex.messaging.services.remoting.adapters.JavaAdapter"
default="true" />
</adapters>
<default-channels>
<channel ref="my-graniteamf" />
</default-channels>
<destination id="pojo">
<channels>
</channels>
<properties>
<scope>session</scope>
<source>com.atosorigin.services.MedewerkerServicce</source>
</properties>
</destination>
</service>
Thank you :)
1 Accepted Solution
Avatar
Correct answer by
Level 1
It's <mx:Label
text="{service.operation.lastresult.desiredProperty}" /> :)
(Note the lack of parentheses at the operation part)
Avatar
Level 1
To add more information:
If I specify the granite-amf channel as default channel, I"ll
get the following error, instead of the first:
[RPC Fault faultString="Send failed"
faultCode="Client.Error.MessageSend"
faultDetail="Channel.Connect.Failed error
NetConnection.Call.Failed: HTTP: Failed: url: '
http://localhost:8080/Medewerkers/graniteamf/amf'"
I'm deploying this all on a Tomcat 6 server and compiled the
MXML beforehand.
Avatar
Former Community Member
I'd suggest replacing server.name, server.port and
context.root with actual values and recompiling you app with
services-config.xml. See if that helps.
Avatar
Level 1
It was a context error, but thanks :) Now I have a response,
but somehow I can't access that response. I receive this:
[AMFMessageServlet] << Returning AMF0 response:
org.granite.messaging.amf.AMF0Message {
version = 3
headers = []
bodies = [
org.granite.messaging.amf.AMF0Body {
target = /3/onResult
serviceName = null
serviceMethodName = null
response =
type = AMF3_OBJECT
value = flex.messaging.messages.AcknowledgeMessage {
correlationId = 4BC2BDA6-7E93-BAFC-D023-0EC9A42F4544
destination = null
headers = {}
messageId = 071A0DFB-FAF1-4ED9-A8A4-8FFD5A316BBF
timestamp = 1194249004126
clientId = E9EB42DA-D843-4226-9A40-7C5E96B2425B
timeToLive = 0
body = com.atosorigin.domain.Medewerker@1b5d2b2
A Medewerker Object and this object has a property voornaam.
So, it should be accessed with the follow code right?:
[Bindable]
public var employee1:Medewerker;
<mx:Label text="{employee1.voornaam}" />
(Leaving out unnecessary code)
Avatar
Correct answer by
Level 1
It's <mx:Label
