SOLVED
Data grid -Column data issue
Avatar
Level 2
i am new to FDS using Flex 2.0.
Is it possible to the data in a datagrid column while loading
the page itself.
I have a product_list which contains hotel name , rate and
status.
Rate will be obtained from the list as say 345. i want to
display it as GBP 345 in datagrid, while page loading
how can i acheive this from client side ( in
actionscript)..?
My code for datagrid is as follows:
<mx:DataGrid id="dg" width="100%" rowHeight="38"
styleName="GridColumnText"
dataProvider="{hotel_details}"
enabled="{!ds.commitRequired}"
creationComplete="fill_hotelDetails()"
verticalScrollPolicy="{mx.core.ScrollPolicy.OFF}"
rowCount="10" height="404">
<mx:columns >
<mx:DataGridColumn dataField="hotel_address"
headerText="Hotel Name"
headerStyleName="DynamicLabel" width="300" wordWrap="true"
editable="false"/>
<mx:DataGridColumn id ="pr_rate"
dataField="prdt_rate" headerText="Rate"
headerStyleName="DynamicLabel" paddingRight="10" editable="false"
width="50" />
<mx:DataGridColumn dataField="hotel_status"
headerText="Availabilty"
headerStyleName="DynamicLabel" editable="false"
width="75"/>
<mx:DataGridColumn headerText="Book Now" editable="false"
headerStyleName="DynamicLabel" width="75"
sortable="false">
<mx:itemRenderer>
<mx:Component>
<mx:HBox width="25%" horizontalCenter="0"
horizontalAlign="center"
styleName="GridColumnText" paddingTop="5">
<mx:Button id="book" label="Book Now"
click="OnBook_click()" />
<mx:Script>
<![CDATA[
public function OnBook_click():void{
var request:URLRequest = new
URLRequest("/quick_search/booking.mxml");
navigateToURL(request,"_self");
</mx:Script>
</mx:HBox>
</mx:Component>
</mx:itemRenderer>
</mx:DataGridColumn>
</mx:columns>
</mx:DataGrid>
In the following code, i want to dispaly pdt_rate as GBP 345.
pls any one give suggestions
thx in advance
Ambili Surendran
1 Accepted Solution
Avatar
Correct answer by
Level 4
I think the best way is to make a label function something
like this (just off the top of my head, not tested):
public function rate_label(item:Object,
column:DataGridColumn):String
return "GBP"+item.prdt_rate;
Then in the DataGridColumn add a property:
labelFunction="rate_label"
Avatar
Correct answer by
Level 4
Avatar
Level 2
hi Robert,
Thank you for ur immediate reply.. .
it worked...
thnx
Ambili surendran
