Help! I've tried downloading Adobe Flash player 10 times but it stops at 30% and will not download anymore. I have a Mac and use safari.
go into avast and select preferences. click on shields. then click on disable for each of the shields.
just did it. worked great.
don't forget to re-enable the shields.
It happens to me the same!
I've tried all possible things and keeps the 30 % !
Ur version is OS X Yosmite 10.10.2?
I have having the same problem (Yosemite 10.10.1 Safari)
Same issue here. Gets hung up at 25% or 30%.
Same issue
GOT IT!
Try to turn off the antivirus, if they fail that was my case, uninstall it, reboot the mac and try to install AFP .
Hope this helps!
I don't have any outside anti-virus software. Is there something native to Mac I need to turn off? If so, how?
Try this , if you can not tell me , I will be happy to help
If you are using Avast Mac Security, you have to disable it first. FlashPlayer will then download successfully. Then re-enable Avast. Simple fix!
No luck with disabling avast mac security.
Got it working late last night. thanks
