When I try to down load book from e library and we go to Adobe Digital Edition 4.0, , instead of downloading the book, I get the error (error check activation). Both the computer and the KOBO have be authorized to account (rhelliott@Hotmail.com)
For this problem, you need to deauthorize and authorize ADE again.
Launch ADE
Help -> Erase authorization.
ADE will be deauhorized.
Now again AUTHORIZE ADE
Help-> authorize computer.
Error will be fixed !!
Hi Shreya, I'm also having trouble deauthorizing ADE. It says my password is wrong. I've tried what you said above:
"Mac: Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
ADE will be deauthorized now.
Now Authorize ADE again."
I can't find the activation.dat file. When I navigate to Users/Library/Application Support/Adobe/ there is no Digital Editions folder.
Ok, try the following way to access activation.dat:
1. Go-> Go to folder.
Go to folder dialog will appear.
2. Type ~/Library/Application Support/Adobe/Digital Editions
Hope this works !!
Shreya, thank you! It worked! I have been trying to get help with this for months now. I'm thrilled to be able to download books again.
When I try to deauthorize, it does not work . I get the following message(unable to erase authorization, please try after some time). And when I try again to deauthorize, it just repeats the same message so all you do is go around and around.
If due to some reason, you are unable to deauthorize ADE, follow the below steps:
Windows:
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Adobe\Adept
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Your authorization will be deleted.
I am having the same issue. I can deauthorize and authorize, but when I try to add the book to my Kobo, the following message appears. " Copy Not Allowed, No Permission To Copy"
Please check the following:
1. Open the file in Adobe Digital Editions.
2. Go to File -> Item Info
Check under permissions, Copying permission
Sherya - I did what you instructed - it this is what was showing:
Permissions license to unknown
copying on any device
How do I change this so that I can copy the book from my laptop to my Nook 1st Edition?
Hello,
please try below steps:
Thanks !
This is an old thread but I am having this problem. I cannot deauthorize. I think the original Digital Editions was downloaded on another computer. I cannot find the activation.dat file to delete it. I cannot find anything that seems to get my books to read again.
Thank you.
Thank you so much! I could not deauthorize but your Registry edit did the trick. Re-authorized and everything working now. Thanks again.
