I am getting an error (A valid installer cold not be found) when trying to create a package using AAMEE. I have used this in the past to package Presenter. I have targeted the path to setup.exe and set-up.exe.
Moving this discussion to the Adobe Presenter forum.
This thread may help: Re: Presenter 10 CCP
I call support for the fix. Since version 9, you have to use the CC Packager.
ftp://cust-dl:$Zwmpl3456@sjftp.adobe.com/ccp1_8/CreativeCloudPackager_1_8_all.exe
Instructions for creating Presenter 10 package for 64-bit OS and 32-bit PowerPoint:
Well I spoke to soon. It seems that the packager does not fix the error. I am still getting an 1603 error in the log file. I ran the MSI with a /log switch to get the log file. I can manually install the program, so there no conflict with any other software.
Here is a more detailed explanation from RajeevAdobe
Instructions for creating Presenter 10 package for 32-bit OS and 32-bit PowerPoint or for 64-bit OS and 64-bit PowerPoint:
Deployment Instructions:
On your machine you have to open Command Prompt, Right click on it and select Run as administrator. In Command Prompt you have to go to the exact path where Presenter package folder is placed and go inside build folder.
Once you are in build folder location in Command Prompt then type the command :- msiexec.exe /i name of the package.msi /quiet and press enter.
After then please open Task manager , In process tab you will see msiexec processes are running and It will install/deploy the Presenter 10 Package silently on your machine.
Rajeev.
