Browse Sequence editor not working for Word imports
Mentor ,
Mar 26, 2015 Mar 26, 2015
Hi
I am using RH10, with Word 2007.
I have imported the Word doc and used its ToC in RH project. However, when I click the Autocreate using ToC in Browse Sequence Editor window, nothing happens.
Is it some sort of known bug? Or am I missing something?
Please advise.
Sreekanth
277
Hi there
Maybe you have more than one TOC?
If so, are you certain you are pointing the Browse Sequence Editor to the correct TOC?
Cheers... Rick
Mentor ,
No Rick. I have only one TOC.
Sreekanth
Hmmm, in looking again, I see you stated you used the TOC from the Word document. What I'm unsure about, is if the process of importing the Word document with a TOC will actually create a corresponding TOC in RoboHelp. I would expect that to be the case but personally I've never tried it.
So the question here is, did that process create a "proper" RoboHelp TOC? If you click the View menu and point at Pods, then TOC, do you actually a new pod open with books and pages inside the pod?
Cheers... Rick
When you import a Word document, whether or not a proper Rh TOC is created depends on whether or not you choose that option. The workflow is documented on my site.
If you do create such a TOC, it can then be inserted into the main menu if required.
@petergrainge
Mentor ,
RH ToC matches Word ToC. I re-created the doc ToC and RH project. Now, I am able to get the Browse Sequence. However, it is not up to the right level.
Here is the screenshot, of browse sequence set at 2nd level.
Apr 02, 2015 Apr 02, 2015
Please clarify what you expect to see in the above image.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
