Trying to set up a DSN for a SQL Server database on a new computer and it's failing every time.
Connection verification failed for data source: csf
java.sql.SQLNonTransientConnectionException: [Macromedia][SQLServer JDBC Driver]Error establishing socket to host and port: SANDYPC:1433. Reason: Connection refused: connect
The root cause was that: java.sql.SQLNonTransientConnectionException: [Macromedia][SQLServer JDBC Driver]Error establishing socket to host and port: SANDYPC:1433. Reason: Connection refused: connect
Now, when I installed CF 11, it installed on port 8500. However, when I try changing the port in the setup to 8500, I get this error:
I cannot find anything online on how to fix this! HELP!!!
Is that SQL Express edition? If so perhaps TCP protocol is not enabled. Is Windows firewall turned on? Check port 1433 is open.
Normally you would not create a datasource to apache port 8500, that is a web server not database server port.
HTH, Carl.
HTH, Carl.
