I'm using X5 so it may be a tad different. The hardcopy
documentation I have available is quite old and doesn't seem to
apply to my version of RH.
I'm just learning how to merge myself. I've inherited a
project that merges several sub-projects into a master project and
now I need to create an entirely new set of projects that I will
eventually merge.
I don't know how this will apply to your situations, but I've
created separate projects for the different content areas I'm
documenting and creating content, links, indexes and the like.
The only difference between a master project and a
sub-project is which one you decide will be the master. Actually, a
master project can be completely empty of content, but I haven't
had the nerve to try that option as yet. Usually there's one
project that is the backbone for the documentation and I use that
for the master.
Here are the steps:
Create each of the projects you want to have combined
including adding any content, links, and so on.
Compile each individual project.
Go to the master project and put your cursor where you want
to merge another project.
Right-click -> New -> Merged project.
In the Merged Project dialog box on the HTML Help tab, use
the browse button to browse to the chm file for the project you
want to merge.
Select the chm file and click OK.
You can drag and drop the merged project so it appears where
you want it to go in the master project's TOC.
Generate the main project again and then view the project to
verify that the merge was successful and appears where you want it.
If it all worked out, when you re-compile the master project
after the merge and view it, you'll see the sub-project books
completely integrated into the master project TOC, as if all the
books were part of a single project.
The only real hang up I've found is that if I make any change
in a sub-project, the only way to get it to show in the master is
to delete both the merge link in the TOC and the sub-project's CHM
from the master's Microsoft_HTML_Help folder. Then I recreate the
merge, re-compile the master project and the changes appear. Let me
know how you get on.
-Trip
