Erika, let me ask you this:
When you insert the swf on your slide, is it just that the
overall size of the flash object is larger than originally designed
in flash? Meaning....that if you created a 200 x 200 animation, it
"inexplicably" resized itself to something much larger than that?
If so, have you tried looking at the swf's dimesions using
the Visual Basic Editor? The reason why I ask is because from time
to time, when I've dropped a swf on a slide, I've noticed that for
some strange reason, the swf ends up a bit larger than what I
designed in flash. I've been able to overcome the problem by using
the VB Editor.
You should be able to double click the swf object on the
slide....this in turn should open up the VB Editor, or you could
right click the flash file on the slide and from the menu that
appears, select "properties". Another dialog box will appear, and
what you need to look for from there is the width and height
parameters. Check to see that the dimensions haven't been messed
with...if so, reset the dimensions (you may need to hit your Enter
key to accept your changes), then close down the Editor panel and
your swf should have resized accordingly.
Please let me know if that helps....and I apologize for not
"hearing" your question right the first time!
Rob
