2 Replies Latest reply on Aug 29, 2015 3:58 PM by rafaels62244494
    Roland Versaworks to CMYK
    bongo3 Level 1
      Hello
      I was wondering if someone could give me the CMYK or Pantone numbers for some Roland Versaworks colors. They are RVW - PR10D and RVW-PR06F. Thanks!!
        • 1. Re: Roland Versaworks to CMYK
          G.Hoffmann Level 4
          If you own Versawork, then you can take the Roland Color Library and put it into Illustrator,
          like any other library. There are videos in the Web, it works as usual.
          If you don't own Versawork, then beware of downloading from obscure sources.
          In Illustrator you can read (hopefully) the Lab values, as it happens for Pantone since some
          years as a standard.
          A couple of swatches can be exported for Adobe Exchange (*.ase). This file can be opened
          in Photoshop and converted swatch by swatch into any other color space, for instance into
          the CMYK space as defined by Color Settings.
          I don't have access to Versawork, and I think that this color library is just another promise
          for wonders, whereas anybody can easily define swatches by Lab, as long as we are not
          talking about metallic or fluorescent or varnish spot inks.
          Best regards --Gernot Hoffmann
          • 2. Re: Roland Versaworks to CMYK
            rafaels62244494 Level 1
            is there a way to convert the color swatches into photoshop
