Has anyone had problems with mapping FM8 styles to RH7
WebHelp (Not Technical Suite). Any ideas about how to map the
paragraph style after the fact? I'm relatively new to RoboHelp, so
I could be missing something obvious.
You can re-import the files to be able to access the style
mappings dialog. If you don't change how the topics are created
(that is, keep the same "Pagination settings" so that your file
names remain the same), it will ask you if you want to overwrite
the files that are already there. I don't see a way to have RH map
the styles after importing, other than to re-import.
Thanks -- I tried that -- This particular format refuses to
display in the import Framemaker formats list in RH -- I've made
sure that the format exists across the entire manual set (even
though it's only used in one chapter) and tried a few other things.
Please check if you have a text entered in the Chapter with
that paragraph format applied. If a paragraph format is applied as
Autonumbering option alone- RoboHelp may not find that in the MIF
document. Enter at least a space with that format.
