Can your creative cloud account give you access to Flash Builder 4.6? 4.7 got rid of the design view, I need to get use out of the design view. Thanks
no, that doesn't look possible.
I wonder why when it would be a downgrade form the version 4.7 my subscription give me access to. There does not seem to any training that uses 4.7 I was lucky enough to find some that uses 4.6 and it covers things about the design view. I thinking since a lot of the material to learn it is kind-a-outdated (and still referrers a lot to design view) that it would be good to learn it with access to design view. This way I will understand what they mean and can distinguish between features. Thanks
<moved from ActionScript 3 to Using Flash Builder>
Hi, I discovered it is possible. All I did was use the installer from the CS6 full collection and it worked. I discovered this when I gave it a try by checking the box when I wanted to install Encore DVD. Interestingly enough I did not even remove the trail. I just installed it over the trail again it works. I does not ask for a serial or to continue the trail anymore. I also have 4.7 running on the same system. I hope of others can benefit from this method. Thanks
