I am running CentOS 6.6 with Apache 2.2.15. All were installed today, on a newly provisioned VMware guest.
When I browse to http://10.213.42.200/CFIDE/administrator/ from my laptop, I get a 500 error. I read that I may need to access from localhost.
So, I installed X windows and a desktop client, then connected to the VMware console for the machine and browsed to localhost. I got the same 500 error.
This is a very vanilla install, and I can make any changes necessary. What suggestions do you have, or what additional information can I provide to gain an answer?
Thank you for pointing me to that file!
I was able to look up the errorINFO: failed to load: coldfusion.CfmServlet and found this thread:
ColdFusion 10 install on RHEL 6.1
The problem was solved when I updated my hosts file and restarted Coldfusion.
Did you run the web server connector after the installation?
I ran it during the installation.
I also tried running it afterwards.
Inside the Coldfusion11 directory (where ever you installed it to) there will be a logs folder. Have a look at coldfusion-out.log to see if there is any clue. Also worth checking the Apache logs to see if it shows anything.
I re-installed CentOS without apache. I installed Coldfusion using ~./ColdFusion_11_WWEJ_linux64.bin, and it still gives me a 500 error. Maybe it's worth mentioning that I installed using the Production+Secure profile. Maybe it's too secure? Also, I set the user as "nobody" in the installer (I ran the installer while logged in as root).
I see this in the log file coldfusion-error.log:
[root@d-webehr-app02 logs]# tail -f coldfusion-error.log
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:422)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
java.lang.NullPointerException
at coldfusion.CfmServlet.init(CfmServlet.java:97)
at coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:121)
at coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59)
at org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1284)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1197)
at org.apache.catalina.core.StandardWrapper.allocate(StandardWrapper.java:864)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:134)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
Apr 01, 2015 1:34:51 AM org.apache.catalina.core.ApplicationContext log
Apr 01, 2015 1:34:51 AM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Allocate exception for servlet CfmServlet
Are you getting anything in the log file that references to issues initialising the licensing service?
I would recommend archiving the log files and then restarting the server, then access the page. This way you should have only the relevant logs.
Good to hear. That was the next thing I was going to recommend.
If you can mark the thread as answered it will help anyone else looking.
