Hi
I am using RH10.
My entire project must use Arial font. But I see the Default Paragraph Font in the default.css is Times New Roman. What does this do? It is grayed out. So, how to change it?
Sreekanth
Open up your Style Sheet, expand the Other section and select the "Background + Text BODY" style. If you change that to use the Arial font. it wil do what you want.
Thanks. That solved it.
But still curious. What is that used for?
Sreekanth
The Background + Text style sets the default for when no style is applied. It is also used as the basis for any new styles created.
Interesting. Thanks for that, Colum!
This old RoboDog learned something new today!
I openly admit that I struggle more with CSS than I should. My term is "Cussing Style Sheets"!
Cheers... Rick
Thanks for the clarification, Colum. Though I don't need it now, I should explore how (and if) I could put it to some good use in RHStyleMapping.css during FM-RH integration.
Sreekanth
