Unable to open a project in RoboHelp 9
Apr 01, 2015 Apr 01, 2015
Till last week my RoboHelp 9 copy was working fine. From yesterday, "Open" dialog box is not showing up. If I click Open icon it will hang. Please help!!
341
LEGEND , Apr 01, 2015 Apr 01, 2015
HI there
Do you have a Windows key on your keyboard? If so, press and hold it, then press the left arrow key two or three times. See if the dialog appears.
Cheers... Rick
HI there
Cheers... Rick
Thanks Rick for the quick help!!
Yes, I am able to get it now. I tried your suggestion it worked. Now, should i try your suggestion every time. Is that the only solution or there any other?  Do you know the reason by any chance...:)
Thanks a lot...:)
Rajani
Hello again
I'm pleased it worked!
When applications appear to "lock up" when you expect to see a dialog, it's a fair guess that the dialog is actually appearing somewhere, but may be in a screen position that is not "viewable". This can happen if perhaps you had the screen set to a really super high resolution, then switched it to a lower resolution. But most commonly it happens when you have been working with a second monitor connected and at some point the second monitor is no longer there. Perhaps in a situation where you have a laptop in a docking station at the workplace, but you disconnect and take the laptop home.
However, I've been using RoboHelp for 20+ years. And over the years I'm aware of one particularly elusive bug with the preview. And in that bug, when it happens, the screen coordinates for the preview window sometimes inexplicably get written where if you had a monitor large enough, the preview would actually appear about ten miles or more away.
Fortunately, the Windows+Left Arrow trick seems to work.
Cheers... Rick
Hi Rick!!
Wow!!! That’s lot of info.
Indeed, you are right. I did use projector for a training last week. I guess, that is the reason it did not display the dialog box.
Well, very nice to know your experience level; So that I can I reach you for any doubts in RH. I am glad...
Thanks once again.
Rajani
Oct 13, 2015 Oct 13, 2015
Hi Rick,
I have the same problem as that of Rajani's. Unable to open the project in RoboHelp 10.0.
The Windows + Left Arrow click did not do the trick
Please help!
Radtuk
RoboHelp Documentation
Download Adobe RoboHelp
