As long as you are familiar with the concepts of HTML/XML
coding it's really easy. If you aren't, it'll look a little scary
at first. I'll post some examples to hopefully help. Make sure you
have RoboHelp closed, and I think you may also need to delete the
cpd file before opening the project again (I
think it remembers some of this stuff and will wipe out your
changes).
The fpj lists all folders and files in a directory. So for
example, this directory contains one subfolder and one topic:
<?xml version="1.0" encoding="windows-1252"?>
<rhpml majorversion="1" minorversion="0">
<folders>
<folder>
<name>Samples</name>
</folder>
</folders>
<topics>
<topic>
<name>Viewing_the_Log.htm</name>
<comments></comments>
<frameset>0</frameset>
</topic>
</topics>
</rhpml>
If there aren't any subfolders, it should be like this:
<folders/>
<topics>
<topic>
</topic>
</topics>
</rhpml>
The main thing is to ensure you get the tag pairs correct. If
you are a bit concerned about getting it wrong, re-importing
(rather than restoring) all the topics "should" add them into the
fpj files correctly.
(fingers crossed that the code displays properly...
