I´m trying to open my e-book into ADE (4.0). My computer S.O is windows 7. I don´t know how to figure this out. Please help me!
For this problem, you need to deauthorize and authorize ADE again.
Launch ADE
Help -> Erase authorization.
ADE will be deauhorized.
Now again AUTHORIZE ADE
Help-> authorize computer.
Error will be fixed !!
Thanks for you help! But i´ve already tried this solution but it didin´t work. When i try to deauthorize, the ADE shows the following message: "Unable to remove the authorization. Please try again later." I tried it yesterday and right now, but it didin´t work. What to do next?
Hello everybody! I fixed the issued with a workaround:
1 - Uninstall 4.0 ADE version;
2- Install the 3.0 ADE version;
3 - Deactivate the device successfully;
4 - Install 4.0 ADE again;
5 - Reauthorize the device and it´s done.
It worked for me!
This worked for me too. It is a great solution. Thank you.
I tried that but the 3.0 version does not give me an option to deauthorize my computer. Any other suggestions?
Try control-shift-D to get the option...worked for me, and I was having the same issues.
I just tried this. Thank you! your suggestion has solve my issue.
Hooray!
That worked! Thank you so much! Still had trouble with one title but I returned it to the library and borrowed it again. Thankfully it wasn't on hold!
that was so perfect! thanks.
This helped me as well. Thank you so much!
