Mac OSX / Safari / Yosemite V 10.10.2 / My iMac does not allow me to upgrade or install a new Flash Player nor uninstall my existing Flash Player. • I have made numerous attempts to make this installation, updated software on my computer, emptied caches, manually deleted my Flash player (i don't have one now), I followed instructions off of the Adobe forum and everywhere I can on the Web, still, no luck. Please advise - any assistance would be greatly appreciated
Here is the alert. Depending on wether its the installer or installer, I always get this
Did you try the following Adobe website? Go down to the bottom where it says "Still having problems?.
Andy - yes I did that as well. I get the same alert: "Check with the developer to make sure Install Adobe Flash Player works with this version of OS X. You may need to reinstall the application. Be sure to install any available updates for the application and OS"
I suggest you post back during the week at which time Adobe staff will help you with that problem.
Copy that. I appreciate you taking the time to assist. Good day
Since it is the uninstaller that encounters a problem, try the manual uninstaller from https://helpx.adobe.com/flash-player/kb/uninstall-flash-player-mac-os.html
P-Willener - Thanks for the link. I've tried this before with no luck. The same alert pops up whoever I try to launch the installer and uninstaller. I'm wondering if there's there a way to manually install this player or related software. Perhaps by going into my folders, deleting and adding. At this point I'm awaiting such instructions from the forum . . . .Thanks again
Hi clemeleon,
Please click the 'report' button on the dialog window and copy and paste the information in the next window here.
What is the name of the file that is exhibiting this behaviour?
Thank you.
Maria
Here you go Maria: this is what the report says. For install and uninstall - both are the same
Install Adobe Flash Player cannot be opened because of a problem.
Check with the developer to make sure Install Adobe Flash Player works with this version of OS X. You may need to reinstall the application. Be sure to install any available updates for the application and OS X.
Click Report to see more detailed information and send a report to Apple.
Hi clemeleon,
I'm actually looking for the information that displays after you click the 'Report...' button. This should provide us more information as to what the problem is.
Thank you.
Maria
There is no additional information included in the report window
Hello Maria - Do you have any additional information for me on this? Can I provide you with anything else?
Maria - I'm just following up on this inquiry.
Hi clemeleon,
Sorry for not getting back to you sooner.
Please verify and repair the disk and permissions on the system Repair disk permissions to speed up your Mac - CNET
You also indicated that you manually removed Flash Player from the system. When you did this, do you recall which files you removed?
Maria
Hi - Thanks for getting back to me. OK - I'm running the disk permissions . . . . . repaired what needed to be repaired in disk utility, and have attempted to relaunch the Flash17 to no avail. I get the same report from before.
I manually removed my Flash drive, from the Adobe folder in applications. I did this in an attempt to uninstall Flash, because I was hitting dead ends with the uninstaller.
This is what the folder looks like . . . No Flash player installed. If you don't get back to me - have a nice easter - we can pick it up after the weekend.
Hello Maria - Wondering if you were able to revisit this case?
Maria - In another attempt to install the Flash Player - I located the details and information. Here is what I found . . . . . There's a lot of data - Hopefully you can ID the issue I'm having . . . Thanks - Chris
Process: Install Adobe Flash Player [24936]
Path: /Volumes/VOLUME/Install Adobe Flash Player.app/Contents/MacOS/Install Adobe Flash Player
Identifier: com.adobe.InstallAdobeFlashPlayer
Version: ???
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: Install Adobe Flash Player [24936]
User ID: 501
Date/Time: 2015-04-11 13:20:32.580 -0700
OS Version: Mac OS X 10.10.2 (14C1514)
Report Version: 11
Anonymous UUID: B54430F0-53E0-EFF1-AD3E-1F452C0EF1FC
Time Awake Since Boot: 79000 seconds
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
Referenced from: /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
Reason: image not found
Binary Images:
0x8fe38000 - 0x8fe6be03 dyld (353.2.1) <06B1254D-9BB9-327C-BA15-8F18FFF97586> /usr/lib/dyld
0x90008000 - 0x90016ff3 libxar.1.dylib (254) <D7C4FDEB-61AA-3FC1-8B7B-0AE3A3A64492> /usr/lib/libxar.1.dylib
0x90164000 - 0x90168ffb com.apple.IOSurface (97.0.1 - 97.0.1) <AE872EA9-0D22-32CF-91AB-DD7C056EB01E> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x90169000 - 0x90171ffb com.apple.NetFS (6.0 - 4.0) <141BFE7E-634E-32A0-8EC9-0A1A4DFEA7D9> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x90172000 - 0x901bbffb libFontRegistry.dylib (134) <023BB8A2-8BBA-30DC-B0C2-A5F0AE3667D8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x903df000 - 0x903e8ffb com.apple.CommonAuth (4.0 - 2.0) <FFE760A3-FEF7-3009-92E8-893ABB3BC91A> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9063d000 - 0x90644ff3 libunwind.dylib (35.3) <29D9343F-9A0A-3535-B0AE-E7CC761D95EE> /usr/lib/system/libunwind.dylib
0x90645000 - 0x90649fff libheimdal-asn1.dylib (398.10.1) <6F113AF8-F5AD-330B-B029-F7AF28A93F28> /usr/lib/libheimdal-asn1.dylib
0x9064a000 - 0x906aeff7 com.apple.AE (681 - 681) <EEE62980-421B-33BD-BB88-6BDE269A3060> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9075d000 - 0x9076aff7 libbz2.1.0.dylib (36) <6BC7B049-8F03-3217-9840-B1804CCBF742> /usr/lib/libbz2.1.0.dylib
0x9076b000 - 0x90770ff7 libcompiler_rt.dylib (35) <6630682F-AB76-3E55-BE51-0A3E61B6CFC2> /usr/lib/system/libcompiler_rt.dylib
0x90811000 - 0x90a07fff libicucore.A.dylib (531.31) <430BD572-4521-3C85-B815-56514F9E2BBF> /usr/lib/libicucore.A.dylib
0x90a08000 - 0x90a0bfff libextension.dylib (55.1) <E0A4ADBE-596E-3363-8780-51D8AE39B755> /usr/lib/libextension.dylib
0x90a0c000 - 0x90a69ff3 com.apple.print.framework.PrintCore (10.0 - 451) <2563665B-7B7F-3B8A-83B1-E5AC8D389909> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x90a6a000 - 0x90b0afff com.apple.QD (301 - 301) <4DFE3689-59DE-3FBC-806B-6A4056573E52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x90b0b000 - 0x90fb2ff7 com.apple.JavaScriptCore (10600 - 10600.3.13) <21BA75F3-8A70-3159-8696-7392EDEBEF70> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x910a3000 - 0x910a5ffb libRadiance.dylib (1232) <F16794FD-4326-32CD-A578-3B2ADB27587D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x910a6000 - 0x910b2ff7 libkxld.dylib (2782.10.72) <FF699F52-D950-3DAD-A37B-834EBF0D0FFD> /usr/lib/system/libkxld.dylib
0x910b3000 - 0x9119ffe7 libvMisc.dylib (516) <8575A3B5-F6FB-35BF-9E50-E81BD0813100> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x911a0000 - 0x91596ff3 com.apple.CoreGraphics (1.600.0 - 775.16) <5F7BDB0B-5324-3B7A-BC6B-E7A01A880D94> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x91597000 - 0x915a8fff libbsm.0.dylib (34) <C9F0C608-2794-3F6B-8078-583FC0046039> /usr/lib/libbsm.0.dylib
0x915ab000 - 0x915adfff libquarantine.dylib (76) <9ADD861F-A66E-3AD1-A77E-C622E91BD203> /usr/lib/system/libquarantine.dylib
0x915fe000 - 0x9161dffb libresolv.9.dylib (57) <C2C3810A-A45E-3375-B41D-6E1BECE1BA3C> /usr/lib/libresolv.9.dylib
0x9161e000 - 0x91648fff libxslt.1.dylib (13) <0F55B64A-6C55-304E-ACE0-B531027AA066> /usr/lib/libxslt.1.dylib
0x91649000 - 0x91677ff7 libarchive.2.dylib (30) <8758D35F-ADF8-30F6-8EB2-9B852876EAC8> /usr/lib/libarchive.2.dylib
0x9175f000 - 0x91761fff libsystem_coreservices.dylib (9) <20E66A47-8D67-344A-A393-73926F0E5FB2> /usr/lib/system/libsystem_coreservices.dylib
0x9176b000 - 0x9176bfff libOpenScriptingUtil.dylib (162) <9872C464-DF90-37C2-9871-8A3F53C615EC> /usr/lib/libOpenScriptingUtil.dylib
0x9176c000 - 0x91781ffb com.apple.MultitouchSupport.framework (262.33.1 - 262.33.1) <E8AF5A36-89A1-38CC-9905-D74A692D0898> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x91782000 - 0x917a8ff3 libc++abi.dylib (125) <E9AF8CA1-D54D-37E3-8363-A3E8C0840F71> /usr/lib/libc++abi.dylib
0x917a9000 - 0x91804ffb libTIFF.dylib (1232) <E5A82202-E766-32DE-9706-86B3B2B73731> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9181b000 - 0x9181dfff com.apple.loginsupport (1.0 - 1) <8B651D8C-53D0-314D-BDD6-74147C4B2E73> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x918b8000 - 0x918c5ff7 com.apple.speech.synthesis.framework (5.3.3 - 5.3.3) <EB79D0BE-75B8-3570-9D91-AE07E42611BD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x918c6000 - 0x918c6fff com.apple.ApplicationServices (48 - 48) <76C301A4-705B-33DE-BA11-C89DCF1EDCDD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91921000 - 0x91929fff libsystem_dnssd.dylib (561.1.1) <45CDAF46-03DE-33DB-A627-14F245993EF2> /usr/lib/system/libsystem_dnssd.dylib
0x9197c000 - 0x91cdbffb com.apple.Foundation (6.9 - 1152.14) <F74F139D-8789-3B60-ADF6-AB6F39444AC4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x91d1b000 - 0x91d95fff com.apple.ApplicationServices.ATS (360 - 375) <4052B5D1-5F16-315A-A03B-14F0A112FC18> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x91d96000 - 0x91dddff3 com.apple.AppleJPEG (1.0 - 1) <C14A2B49-A664-3EDE-9B9B-6A678ED7F8DE> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x91e32000 - 0x9226dfeb com.apple.vImage (8.0 - 8.0) <56F6B317-9D70-3DC5-9868-BB6D7CB6E55D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9226e000 - 0x92281fff libcmph.dylib (1) <2449B048-208E-36FB-9DFA-47E0F3BCF132> /usr/lib/libcmph.dylib
0x9228c000 - 0x922a9fff libCRFSuite.dylib (34) <781A92EF-410E-39B2-953D-FEE12748D834> /usr/lib/libCRFSuite.dylib
0x922df000 - 0x922dffff libunc.dylib (29) <CE960997-9D4A-3848-BAC7-B2255E6765FD> /usr/lib/system/libunc.dylib
0x92324000 - 0x92424ff7 com.apple.LaunchServices (644.12.4 - 644.12.4) <D41066A1-FC8B-34A2-A980-4B011AA77F38> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x92477000 - 0x9247dff7 libsystem_networkextension.dylib (167.1.10) <FC20E3AD-A53D-3346-AC71-829E82832AE8> /usr/lib/system/libsystem_networkextension.dylib
0x9247e000 - 0x9248eff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <DBECFAD5-DB53-390C-AE92-09549733C861> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9248f000 - 0x924a6fff libsystem_asl.dylib (267) <85BD88AD-618E-3325-AC31-10DBAB8E9AF3> /usr/lib/system/libsystem_asl.dylib
0x924a7000 - 0x924b2ff7 com.apple.NetAuth (5.0 - 5.0) <D6C31218-47E4-3553-9208-D1091A81044E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x924b3000 - 0x9251fff3 com.apple.datadetectorscore (6.0 - 396.1.1) <93F59488-6CA9-3C90-8E96-B0DE5942252F> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x92520000 - 0x92691ffb libBLAS.dylib (1128) <ACEF468C-5DB1-38F3-BCB2-6F3D7F2B2040> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x92703000 - 0x92777fff com.apple.Heimdal (4.0 - 2.0) <5BB21A72-99E6-3079-824E-935AA93D3981> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x92850000 - 0x92850fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <F968D12F-F59D-3148-951D-76735C3C1B57> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x92851000 - 0x92856ff7 libmacho.dylib (862) <48DE74F8-09E3-344F-A82F-665083A3BF8F> /usr/lib/system/libmacho.dylib
0x92900000 - 0x92a04ff7 libJP2.dylib (1232) <CD0012B6-D649-327B-B7FA-E52B0FC0067C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x92a09000 - 0x92a0fff7 libsystem_trace.dylib (72.1.3) <E1985F9C-78FC-3098-8683-81F0DCEE54BB> /usr/lib/system/libsystem_trace.dylib
0x92a33000 - 0x92a33fff com.apple.CoreServices (62 - 62) <FF296ED2-0F90-3055-BBE4-7BF9E42322EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x92a68000 - 0x92abdff3 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <F5A586C3-A440-3E0E-966A-7841A182E5B2> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x92d77000 - 0x92df6fff com.apple.SystemConfiguration (1.14 - 1.14) <21296E7B-11A3-35C0-BDC7-838392DE8298> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x92e32000 - 0x93130ff7 com.apple.CoreServices.CarbonCore (1108.2 - 1108.2) <D3DD9764-A787-3B6B-9DAD-55CEED944DCF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x93131000 - 0x93160ff7 com.apple.DictionaryServices (1.2 - 229) <1F5C35C7-67AA-30A0-A366-EB4B361152A3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x93161000 - 0x9317afff com.apple.Kerberos (3.0 - 1) <92735F11-CF1C-3FA6-8682-9A30AC9E2651> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9317e000 - 0x9330dff3 libsqlite3.dylib (168) <C3F78985-C19B-3320-9F71-543969632128> /usr/lib/libsqlite3.dylib
0x9330e000 - 0x93395fff com.apple.CoreServices.OSServices (640.3 - 640.3) <C53DBDE3-F9E0-3B90-963E-0FAEEF3DA225> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x93396000 - 0x933d6fff libauto.dylib (186) <1609D0F9-6E3A-3C67-87EF-BB0BD93EDAC9> /usr/lib/libauto.dylib
0x933d8000 - 0x9340bfe3 libsystem_m.dylib (3086.1) <951F633F-57B7-398B-912F-F6ED4DB1C597> /usr/lib/system/libsystem_m.dylib
0x93414000 - 0x93415fff libDiagnosticMessagesClient.dylib (100) <3EE83437-AA9C-356B-810B-589346B73797> /usr/lib/libDiagnosticMessagesClient.dylib
0x93416000 - 0x9341fff7 libsystem_notify.dylib (133.1.1) <B8503E99-214B-3AC3-A7CA-CC837ABD7B25> /usr/lib/system/libsystem_notify.dylib
0x93420000 - 0x9342eff7 libz.1.dylib (55) <DF3B8F77-8931-3A6B-8BDF-DB67315050E6> /usr/lib/libz.1.dylib
0x934a5000 - 0x934a8fff libdyld.dylib (353.2.1) <3E28E996-50B8-388B-8885-7299FBC978B1> /usr/lib/system/libdyld.dylib
0x934a9000 - 0x934b8ff3 com.apple.opengl (11.1.1 - 11.1.1) <212B409C-AF1E-3C69-B4AA-57A39C35BB62> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x934ba000 - 0x934bafff liblaunch.dylib (559.10.3) <DF6BB29C-8F20-3E04-81FF-19FFBC82BD46> /usr/lib/system/liblaunch.dylib
0x934bb000 - 0x934bdff7 libsystem_sandbox.dylib (358.1.1) <6031346B-57B0-36FB-911B-D355E1F98A9A> /usr/lib/system/libsystem_sandbox.dylib
0x934be000 - 0x93553fff libsystem_c.dylib (1044.10.1) <584F66B1-ABBA-354C-8118-1DA5386A065E> /usr/lib/system/libsystem_c.dylib
0x93554000 - 0x93577fff libJPEG.dylib (1232) <C7B71F9A-E740-307B-A9FA-A83760EE747B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x93578000 - 0x9359ffff libdispatch.dylib (442.1.4) <B26A176C-39F7-3362-B128-27B1211068B9> /usr/lib/system/libdispatch.dylib
0x935d2000 - 0x935d3fff libSystem.B.dylib (1213) <BFFB2AB8-29F6-3779-B358-EE1F46520FC8> /usr/lib/libSystem.B.dylib
0x935d4000 - 0x939bcff7 libLAPACK.dylib (1128) <4E3D1289-2C98-3E53-BB8D-AD911357FF66> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x939bd000 - 0x939c9ff3 libcommonCrypto.dylib (60061) <024B3913-15C6-3005-9E5A-EB24918F6977> /usr/lib/system/libcommonCrypto.dylib
0x939ca000 - 0x93d7cff7 com.apple.CoreFoundation (6.9 - 1152) <93C32AF9-FD62-3DBD-85F7-35727E6CAA55> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x93d7d000 - 0x93dd0fff libstdc++.6.dylib (104.1) <D0EB2C99-5939-3ABA-9C18-D9AD75CE23A1> /usr/lib/libstdc++.6.dylib
0x93dda000 - 0x93ed0ff7 libxml2.2.dylib (26) <2F37833C-4D55-3A09-9A0C-5904E8B6892A> /usr/lib/libxml2.2.dylib
0x93ed1000 - 0x93ed9fff com.apple.CoreServices.FSEvents (1210 - 1210) <FC372799-6E8E-3290-9816-6981D39BC9D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x93eef000 - 0x9416bff7 com.apple.security (7.0 - 57031.10.10) <3EF32688-A176-33DD-BA59-25F37D6C08DA> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9416c000 - 0x9416ffff com.apple.xpc.ServiceManagement (1.0 - 1) <D0A00D0C-D37D-3CF1-9EE0-41A88BC112BB> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x94170000 - 0x94189fff libsystem_malloc.dylib (53.1.1) <58CD8BC7-55D1-3862-8E5D-728EE2EBE447> /usr/lib/system/libsystem_malloc.dylib
0x9418a000 - 0x941a9fff libsystem_kernel.dylib (2782.10.72) <C88D4054-EF6D-31F9-A9DC-B74160B91C26> /usr/lib/system/libsystem_kernel.dylib
0x9423d000 - 0x94353ff7 com.apple.CoreText (352.0 - 454.3) <6448E389-AB2E-34EF-AE07-FE364ECC98E5> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x94354000 - 0x943cafff com.apple.securityfoundation (6.0 - 55126) <E7CBF2F4-2A0E-3C82-BE84-E09D21772AFB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x943cb000 - 0x9441cfff libcups.2.dylib (408) <08C5D411-533C-345A-B820-092C96215F2E> /usr/lib/libcups.2.dylib
0x9441d000 - 0x94471fff com.apple.HIServices (1.22 - 520.12) <8950B516-7DFD-3154-B34F-067809086832> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x94472000 - 0x94498ffb libPng.dylib (1232) <576BCAB6-DBE2-36DB-A390-E945FC844118> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x94499000 - 0x944effff libc++.1.dylib (120) <D8DE4962-66CD-3491-904E-9291EEE5E570> /usr/lib/libc++.1.dylib
0x94548000 - 0x94639ffb libiconv.2.dylib (42) <4AF77F10-0BEC-3BE0-99DF-C5170EDB316B> /usr/lib/libiconv.2.dylib
0x9463a000 - 0x94643fff libcopyfile.dylib (118.1.2) <FAF3268F-C580-33D3-A5B4-74B8A8713216> /usr/lib/system/libcopyfile.dylib
0x94644000 - 0x94648ff3 com.apple.TCC (1.0 - 1) <3E7036F2-9706-3116-8126-16F26AA2FC11> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x94649000 - 0x94663ff7 liblzma.5.dylib (7) <D0BC984D-5B33-328C-8F1E-7E9C41813433> /usr/lib/liblzma.5.dylib
0x94664000 - 0x94868ff3 com.apple.CFNetwork (720.2.4 - 720.2.4) <2BDDB692-8973-3B53-A53C-71D42BDBABBF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x94869000 - 0x94871fff libsystem_pthread.dylib (105.10.1) <4A229519-29A1-3ABF-8CEF-43BCE4ACDA06> /usr/lib/system/libsystem_pthread.dylib
0x94872000 - 0x94b05fff com.apple.CoreData (111 - 526.1) <74375077-8AE6-3D1B-B6A4-CF3B0724EB60> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x94b06000 - 0x94b38ffb com.apple.GSS (4.0 - 2.0) <680D3014-D2C6-30D4-9892-93B9E4172100> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x94b7a000 - 0x94b8bfff libsystem_coretls.dylib (35.10.1) <602048AB-2CF0-3083-9D84-5DF19B95EEE1> /usr/lib/system/libsystem_coretls.dylib
0x94b8c000 - 0x94ee4ff7 libmecabra.dylib (666.2) <DB0D4D7E-AA7B-3D2D-8936-07F03038F4DF> /usr/lib/libmecabra.dylib
0x94fb1000 - 0x95027ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <B6F346D2-BF88-3925-B962-E59267FA2268> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x95028000 - 0x95043ff7 com.apple.CFOpenDirectory (10.10 - 187) <5302DBFA-92CE-349C-981C-2BF6E9BEEBB0> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x95044000 - 0x95151fe3 libvDSP.dylib (516) <53F7A960-01E1-3B79-A7FD-67BD19471420> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x95152000 - 0x95316ff3 com.apple.QuartzCore (1.10 - 361.15) <4DD4BF91-26D4-3325-BB42-9642318307FA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x95317000 - 0x95320fff com.apple.DiskArbitration (2.6 - 2.6) <D906604A-1D8C-31BF-8F22-EA219FFC858F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x95450000 - 0x95594fff com.apple.ImageIO.framework (3.3.0 - 1232) <3C219D4C-9B88-3A4A-A266-AEA6C6495676> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x95889000 - 0x95a14ffb com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <44BCEAB8-306D-307F-92C8-6656F3578220> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x95a15000 - 0x95c042ef libobjc.A.dylib (647) <7648C174-3098-3B26-AD20-490DBFFD5D4C> /usr/lib/libobjc.A.dylib
0x95cd7000 - 0x95cd8fff libsystem_blocks.dylib (65) <5D98F022-E863-31D4-8ADE-D53B2AE0D331> /usr/lib/system/libsystem_blocks.dylib
0x95cd9000 - 0x95cdbfff libsystem_configuration.dylib (699.1.5) <76B9BA28-179E-34FA-B10B-E625022A29CB> /usr/lib/system/libsystem_configuration.dylib
0x95cdc000 - 0x95d37fff com.apple.LanguageModeling (1.0 - 1) <9B39E059-F48E-31AF-B1B3-B0872F362627> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x95d38000 - 0x95d38fff libkeymgr.dylib (28) <06DDCEF8-EB84-3F68-9E19-FD1A12B764FD> /usr/lib/system/libkeymgr.dylib
0x95d39000 - 0x95db6ff3 com.apple.framework.IOKit (2.0.2 - 1050.10.8) <60574F96-1CD6-34B8-A862-EA977FD058BF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x95db7000 - 0x95dbdff3 libsystem_platform.dylib (63) <509993B7-3F26-3360-B899-0BBB15152516> /usr/lib/system/libsystem_platform.dylib
0x95dbe000 - 0x95e64fff com.apple.Metadata (10.7.0 - 917.1) <0B19C2DD-A71C-3D2B-AB00-68FFC6CC606A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9615c000 - 0x961c5ff7 libcorecrypto.dylib (233.1.2) <F188C1A7-E88F-3EC5-A6AA-22C02E3F0C93> /usr/lib/system/libcorecrypto.dylib
0x961c9000 - 0x96206ff7 libsystem_network.dylib (411.1) <EB71DD61-9515-3F6C-817E-25AF7F108CB8> /usr/lib/system/libsystem_network.dylib
0x96207000 - 0x96208fff libremovefile.dylib (35) <49DCAF7B-4466-3775-9E58-EA5D7CBA8AE0> /usr/lib/system/libremovefile.dylib
0x9663d000 - 0x9663fffb libsystem_secinit.dylib (18) <3CBA3BD3-8BA2-358D-BD1A-A1C3DF5D84E6> /usr/lib/system/libsystem_secinit.dylib
0x96640000 - 0x966dafff com.apple.ColorSync (4.9.0 - 4.9.0) <091CDCEC-1B25-3FE7-94C2-8AEFA6564E95> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x97244000 - 0x9733bff7 libFontParser.dylib (134.1) <AF60B79A-410B-389E-9B24-09B5BC61E19F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x974e3000 - 0x974e6fff libpam.2.dylib (20) <E2F34522-448A-3392-BC1D-6625BEB612B9> /usr/lib/libpam.2.dylib
0x974e7000 - 0x97510ff7 libsystem_info.dylib (459) <4F7A7111-7F0D-3891-9DC9-41F5D79949FE> /usr/lib/system/libsystem_info.dylib
0x97511000 - 0x97537ffb libxpc.dylib (559.10.3) <6C4CEB0F-0044-3B62-A286-5693C3FD239E> /usr/lib/system/libxpc.dylib
0x97542000 - 0x97546ffb libcache.dylib (69) <55501A00-AF64-3554-8F46-8D5AFEDEC332> /usr/lib/system/libcache.dylib
0x978d8000 - 0x978d9fff liblangid.dylib (117) <34A0F807-755F-300B-B01F-AABAE3838451> /usr/lib/liblangid.dylib
0x978da000 - 0x978dafff com.apple.Accelerate (1.10 - Accelerate 1.10) <C2367B5B-AE20-3084-A864-104743BE478E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9820c000 - 0x98219fff com.apple.OpenDirectory (10.10 - 187) <14AA5E0C-238A-32C4-BAF3-81893750B5A9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9821a000 - 0x9821effb libGIF.dylib (1232) <037E01F1-885C-3F4A-A353-87DB1F9CB504> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9821f000 - 0x98236ff3 libLinearAlgebra.dylib (1128) <B20FAAAA-1C76-3B20-B100-5FC90F7FE023> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
Model: iMac12,2, BootROM IM121.0047.B1F, 4 processors, Intel Core i5, 2.7 GHz, 16 GB, SMC 1.72f2
Graphics: AMD Radeon HD 6770M, AMD Radeon HD 6770M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x01BA, 0x202020202020202020202020202020202020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x01BA, 0x202020202020202020202020202020202020
Memory Module: BANK 0/DIMM1, 4 GB, DDR3, 1333 MHz, 0x01BA, 0x202020202020202020202020202020202020
Memory Module: BANK 1/DIMM1, 4 GB, DDR3, 1333 MHz, 0x01BA, 0x202020202020202020202020202020202020
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.74.0-P2P
Bluetooth: Version 4.3.2f6 15235, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: ST31000528AS, 1 TB
Serial ATA Device: HL-DT-STDVDRW GA32N
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: My Passport 07B8
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: iPhone
USB Device: IR Receiver
USB Device: Internal Memory Card Reader
Thunderbolt Bus: iMac, Apple Inc., 25.1
Hi Chris,
Sorry for not responding sooner.
Thank you for posting the details of the error as it should provide additional information for debugging. What is the name of the file that is resulting in this behaviour? This will confirm if it's the online or offline installer and allow me to forward the details to the correct developer for troubleshooting.
Regarding your post on Apr 4, 2015 (post #14), the screenshot you posted is a component of Adobe AIR, not Flash Player. I realize it's confusing, since the file is in a folder named "Flash Player". If you've deleted this file I recommend re-installer Adobe AIR. The How to perform a "clean install" of Flash Player in Mac OS X FAQ lists all the Flash Player related files on a Mac system.
Maria
