I work at a public library - we now have at least three customers affected by the issue where ADE quits unexpectedly after a .acsm file is opened and during the fulfillment stage.
All three customers are using Mac OS 10.10.2. One person is using 4.0.1, one person is using 4.0.2, and one person is using 4.0.3.
They are seeing the following info in the system error dialog:
Exception type:
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Further down the thread they see:
Logical CPU: 1
Error Code: 0x00000004
Trap Number: 14
The ebook vendor has advised us to have customers roll back to ADE version 3.0, and have customers re-authorize.
Does Adobe have a solution for this issue other than rolling back?
I tried to speak with a chat agent about this issue and was referred to this forum. A poor customer service experience overall even though the chat operators are polite and tried to help as best they could.
Thank you,
Holly
Thanks Holly for the confirmation that it is working for you post the update.
I would request you all to please install the latest version build for Adobe Digital Edition from - Download | Adobe Digital Editions and then test if it fixes the issue for you and let us know in case you face any issues.
Sharad
Hi Holly,
Is each individual user seeing crashes each time they attempt to open the same acsm file or even with different files?
Would you also be able to confirm if the acsm file they are opening is located on the local machine hard-drive, or a flash drive or from a network share? In case it from anything other than the local hard drive, would be able to have one of the user test it by placing the acsm file locally on the machine.
Would it be possible to have one of them also test it using a sample eBook from the Sample eBook Library | Adobe Digital Editions to check if they see a crash with one of these as well?
Sharad
I am seeing this problem exactly. I upgraded from 4.0.2 to 4.0.3 and it did not resolve. Your sample books work fine and show "copying allowed" as one would expect.
I am logged into my library account, and downloading an ePub book immediately launches the ADE software. I can read the book on my mac, and it appears to transfer to my Kobo, but when properly ejected and then opened on the kobo I get a DRM warning about it not being authorized for my ID.
"Item Info" shows "copying not allowed", and yet "licensed to" matches my adobe ID. Infuriating.
I used to be able to trigger a crash in 4.0.2 by launching the book off the Kobo within ADE. The only string I still had in my clipboard is:
Exception Type: | EXC_BAD_ACCESS (SIGSEGV) Exception Codes: | KERN_INVALID_ADDRESS at 0x0000000000000000 |
It seems 4.0.3 handles this more gracefully and doesn't crash ADE. I'd call that progress if it didn't strip me of what little trouble-shooting information I had available to me.
My wife asked me just now "how do normal people ever get these things to work?".
Something to pass up the Adobe food chain...
OK, I lied. I am able to initiate a crash by launching a book that was within the library before the upgrade to 4.0.3. Running Mac 10.10.
Process: | Adobe Digital Editions [716] |
Path: | /Applications/Adobe Digital Editions 4.0.app/Contents/MacOS/Adobe Digital Editions |
Identifier: | com.adobe.adobedigitaleditions.app |
Version: | 4.0.3 (1) |
Code Type: | X86-64 (Native) |
Parent Process: | ??? [1] |
Responsible: | Adobe Digital Editions [716] |
User ID: | 501 |
Date/Time: | 2015-04-07 20:39:29.735 -0600 |
OS Version: | Mac OS X 10.10 (14A389) |
Report Version: | 11 |
Anonymous UUID: |
Time Awake Since Boot: 3800 seconds
Crashed Thread: | 0 Dispatch queue: com.apple.main-thread |
Exception Type: | EXC_BAD_ACCESS (SIGSEGV) |
VM Regions Near 0:
__TEXT | 0000000102046000-00000001028b2000 [ 8624K] r-x/rwx SM=COW /Applications/Adobe Digital Editions 4.0.app/Contents/MacOS/Adobe Digital Editions |
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.adobe.adobedigitaleditions.app 0x00000001022dc3a9 DRMDecryptor::MakeFilterContext(std::__1::shared_ptr<ePub3::ManifestItem const>) const + 355
1 ePub3.dylib | 0x0000000103325ebb ePub3::FilterChainSyncStream::FilterChainSyncStream(std::__1::unique_ptr<ePub3::ByteStream, std::__1::default_delete<ePub3::ByteStream> >&&, std::__1::vector<std::__1::shared_ptr<ePub3::ContentFilter>, std::__1::allocator<std::__1::shared_ptr<ePub3::ContentFilter> > >&, std::__1::shared_ptr<ePub3::ManifestItem const>) + 339 | |
2 ePub3.dylib | 0x00000001033282fb std::__1::shared_ptr<ePub3::FilterChainSyncStream> std::__1::shared_ptr<ePub3::FilterChainSyncStream>::make_shared<std::__1::unique_ptr<ePub3::ByteStream, std::__1::default_delete<ePub3::ByteStream> >, std::__1::vector<std::__1::shared_ptr<ePub3::ContentFilter>, std::__1::allocator<std::__1::shared_ptr<ePub3::ContentFilter> > >&, std::__1::shared_ptr<ePub3::ManifestItem const>&>(std::__1::unique_ptr<ePub3::ByteStream, std::__1::default_delete<ePub3::ByteStream> >&&, std::__1::vector<std::__1::shared_ptr<ePub3::ContentFilter>, std::__1::allocator<std::__1::shared_ptr<ePub3::ContentFilter> > >&&&, std::__1::shared_ptr<ePub3::ManifestItem const>&&&) + 125 | |
3 ePub3.dylib | 0x0000000103326ffd ePub3::FilterChain::GetSyncFilteredOutputStreamForManifestItem(std::__1::shared_ptr<ePub3::ManifestItem const>) const + 437 | |
4 ePub3.dylib | 0x00000001032dc64a ePub3::Package::SyncContentStreamForItem(std::__1::shared_ptr<ePub3::ManifestItem const>) const + 270 | |
5 ePub3.dylib | 0x00000001032ecf9a ePub3::ManifestItem::ReferencedDocument() const + 176 | |
6 ePub3.dylib | 0x00000001032cf2b0 ePub3::PackageBase::NavTablesFromManifestItem(std::__1::shared_ptr<ePub3::PackageBase>, std::__1::shared_ptr<ePub3::ManifestItem>) + 118 | |
7 ePub3.dylib | 0x00000001032d73c7 ePub3::Package::Unpack() + 26647 |
8 com.adobe.adobedigitaleditions.app 0x0000000102379362 BookContainer::OpenFile(ePub3::string const&) + 2222
9 com.adobe.adobedigitaleditions.app 0x0000000102379c2f BookContainer::OpenContainerForDRMModule(ePub3::string const&) + 43
10 com.adobe.adobedigitaleditions.app 0x00000001022db029 DRMModule::ProcessFile(ePub3::string const&, ePub3::launch) + 1007
11 ePub3.dylib | 0x00000001032b1efb ePub3::ContentModuleManager::LoadContentAtPath(ePub3::string const&, ePub3::launch) + 793 | |
12 ePub3.dylib | 0x00000001032c9f7c ePub3::Container::OpenContainer(ePub3::string const&) + 68 |
13 com.adobe.adobedigitaleditions.app 0x00000001021bd17f dpdoc::Document::getPackageProps(char const*) + 311
14 com.adobe.adobedigitaleditions.app 0x00000001020f78b2 _reader_create(char const*, RECORD_TYPE, void**, char*, unsigned int*, signed char) + 220
15 com.adobe.adobedigitaleditions.app 0x0000000102052554 +[Reader createReaderHandle:type:readerHandle:errorString:] + 104
16 com.adobe.adobedigitaleditions.app 0x0000000102062012 -[MainWindowController openBookInReadingView:errorString:] + 184
17 com.adobe.adobedigitaleditions.app 0x0000000102062379 -[MainWindowController onReadInMainWindow:] + 264
18 com.apple.CoreFoundation | 0x00007fff82bd8cbc __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 | |
19 com.apple.CoreFoundation | 0x00007fff82aca1b4 _CFXNotificationPost + 3140 | |
20 com.apple.Foundation | 0x00007fff8d154ea1 -[NSNotificationCenter postNotificationName:object:userInfo:] + 66 |
21 com.adobe.adobedigitaleditions.app 0x00000001020acdd6 -[DECardView cardItemDoubleClick:withEvent:] + 86
22 com.adobe.adobedigitaleditions.app 0x00000001020adf74 -[DECardItemView mouseDown:] + 240
23 com.apple.AppKit | 0x00007fff880fdfef -[NSWindow _reallySendEvent:] + 12827 | |
24 com.apple.AppKit | 0x00007fff87b8865c -[NSWindow sendEvent:] + 368 |
25 com.adobe.adobedigitaleditions.app 0x000000010207fc6f -[CustomWindow sendEvent:] + 64
26 com.apple.AppKit | 0x00007fff87b3a1e6 -[NSApplication sendEvent:] + 2238 |
27 com.adobe.adobedigitaleditions.app 0x0000000102086023 -[CustomApplication sendEvent:] + 52
28 com.apple.AppKit | 0x00007fff879c6fe8 -[NSApplication run] + 711 | |
29 com.apple.AppKit | 0x00007fff879b2424 NSApplicationMain + 1832 |
30 com.adobe.adobedigitaleditions.app 0x0000000102047604 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib | 0x00007fff8dc6322e kevent64 + 10 | |
1 libdispatch.dylib | 0x00007fff90793a6a _dispatch_mgr_thread + 52 |
Thread 2:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib | 0x00007fff8dc5d52e mach_msg_trap + 10 | |
1 libsystem_kernel.dylib | 0x00007fff8dc5c69f mach_msg + 55 | |
2 com.apple.CoreFoundation | 0x00007fff82b2cb14 __CFRunLoopServiceMachPort + 212 | |
3 com.apple.CoreFoundation | 0x00007fff82b2bfdb __CFRunLoopRun + 1371 | |
4 com.apple.CoreFoundation | 0x00007fff82b2b838 CFRunLoopRunSpecific + 296 | |
5 com.apple.CFNetwork | 0x00007fff8879ae90 +[NSURLConnection(Loader) _resourceLoadLoop:] + 434 | |
6 com.apple.Foundation | 0x00007fff8d1bab7a __NSThread__main__ + 1345 | |
7 libsystem_pthread.dylib | 0x00007fff8e4c12fc _pthread_body + 131 | |
8 libsystem_pthread.dylib | 0x00007fff8e4c1279 _pthread_start + 176 | |
9 libsystem_pthread.dylib | 0x00007fff8e4bf4b1 thread_start + 13 |
Thread 3:
5 com.apple.AppKit | 0x00007fff87b368f7 _NSEventThread + 137 | |
6 libsystem_pthread.dylib | 0x00007fff8e4c12fc _pthread_body + 131 | |
7 libsystem_pthread.dylib | 0x00007fff8e4c1279 _pthread_start + 176 | |
8 libsystem_pthread.dylib | 0x00007fff8e4bf4b1 thread_start + 13 |
Thread 4:: com.apple.CFSocket.private
0 libsystem_kernel.dylib | 0x00007fff8dc623f6 __select + 10 | |
1 libsystem_pthread.dylib | 0x00007fff8e4c12fc _pthread_body + 131 | |
2 libsystem_pthread.dylib | 0x00007fff8e4c1279 _pthread_start + 176 | |
3 libsystem_pthread.dylib | 0x00007fff8e4bf4b1 thread_start + 13 |
Thread 5:: JavaScriptCore::BlockFree
0 libsystem_kernel.dylib | 0x00007fff8dc62132 __psynch_cvwait + 10 | |
1 libc++.1.dylib | 0x00007fff8b201c95 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47 | |
2 com.apple.JavaScriptCore | 0x00007fff898a12d4 JSC::BlockAllocator::blockFreeingThreadMain() + 228 | |
3 com.apple.JavaScriptCore | 0x00007fff89896a9f WTF::wtfThreadEntryPoint(void*) + 15 | |
4 libsystem_pthread.dylib | 0x00007fff8e4c12fc _pthread_body + 131 | |
5 libsystem_pthread.dylib | 0x00007fff8e4c1279 _pthread_start + 176 | |
6 libsystem_pthread.dylib | 0x00007fff8e4bf4b1 thread_start + 13 |
Thread 6:: JavaScriptCore::Marking
2 com.apple.JavaScriptCore | 0x00007fff898a186b JSC::GCThread::waitForNextPhase() + 171 | |
3 com.apple.JavaScriptCore | 0x00007fff898a16c8 JSC::GCThread::gcThreadMain() + 88 | |
4 com.apple.JavaScriptCore | 0x00007fff89896a9f WTF::wtfThreadEntryPoint(void*) + 15 | |
5 libsystem_pthread.dylib | 0x00007fff8e4c12fc _pthread_body + 131 | |
6 libsystem_pthread.dylib | 0x00007fff8e4c1279 _pthread_start + 176 | |
7 libsystem_pthread.dylib | 0x00007fff8e4bf4b1 thread_start + 13 |
Thread 7:: DFG Worklist Worker Thread
1 com.apple.JavaScriptCore | 0x00007fff89b98f1b JSC::DFG::Worklist::runThread(JSC::DFG::ThreadData*) + 219 | |
2 com.apple.JavaScriptCore | 0x00007fff89896a9f WTF::wtfThreadEntryPoint(void*) + 15 | |
3 libsystem_pthread.dylib | 0x00007fff8e4c12fc _pthread_body + 131 | |
4 libsystem_pthread.dylib | 0x00007fff8e4c1279 _pthread_start + 176 | |
5 libsystem_pthread.dylib | 0x00007fff8e4bf4b1 thread_start + 13 |
Thread 8:: FTL Worklist Worker Thread
Thread 9:
0 libsystem_kernel.dylib | 0x00007fff8dc62946 __workq_kernreturn + 10 | |
1 libsystem_pthread.dylib | 0x00007fff8e4bf4a1 start_wqthread + 13 |
Thread 10:
Thread 11:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00007fff5dbb4de8 rbx: 0x00007fff5dbb4eb0 rcx: 0x000000000005dc66 rdx: 0x000000000005dc65
rdi: 0x0000000000000000 rsi: 0x0000000000000008 rbp: 0x00007fff5dbb4e80 rsp: 0x00007fff5dbb4db0
r8: 0x000000000000002f r9: 0x0000000000000000 r10: 0x0000000000000071 r11: 0x000060800085a400
r12: 0x00006000001cf3d8 r13: 0x0000600000825be0 r14: 0x0000000000000f60 r15: 0x0000000000000000
rip: 0x00000001022dc3a9 rfl: 0x0000000000010202 cr2: 0x0000000000000000
Logical CPU: | 1 |
Error Code: | 0x00000004 |
Trap Number: | 14 |
Binary Images:
0x102046000 - | 0x1028b1ff7 +com.adobe.adobedigitaleditions.app (4.0.3 - 1) <05B2F60F-6C68-3505-9A5A-22A2278B3F4C> /Applications/Adobe Digital Editions 4.0.app/Contents/MacOS/Adobe Digital Editions | |
0x1032aa000 - | 0x1033b1ff7 +ePub3.dylib (0) <0C89926F-2852-3406-8A5A-35C20F7A6066> /Applications/Adobe Digital Editions 4.0.app/Contents/Frameworks/ePub3.dylib | |
0x103458000 - | 0x10348dff7 libssl.0.9.8.dylib (52) <70680606-475F-3C89-BB5F-E274253DC7C6> /usr/lib/libssl.0.9.8.dylib | |
0x10367c000 - | 0x10367cff5 +cl_kernels (???) <B03D7268-399D-4AE0-AA5B-808EC91F565C> cl_kernels | |
0x103681000 - | 0x103682ff5 +cl_kernels (???) <1412F5EB-B0E2-4307-A9F2-E907D53B3317> cl_kernels | |
0x106d29000 - | 0x106d29ff5 +cl_kernels (???) <052302FC-B57B-448D-8E3D-628256FEC1FB> cl_kernels | |
0x106e17000 - | 0x106e1bfff com.apple.audio.AppleHDAHALPlugIn (266.5 - 266.5) <641E8CC7-34C5-30A8-A415-16277D54B57E> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn | |
0x1073be000 - | 0x1074a4fef unorm8_bgra.dylib (2.4.5) <90797750-141F-3114-ACD0-A71363968678> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib | |
0x1074f8000 - | 0x1074f8fff +cl_kernels (???) <8C0D3704-BD2D-4F68-8FD8-B3D2067F4467> cl_kernels | |
0x108ee4000 - | 0x108ee4ffe +cl_kernels (???) <E97A6EC6-DC7E-4789-A952-437431BD1D90> cl_kernels | |
0x108ee8000 - | 0x108ee8fff +cl_kernels (???) <8C0D3704-BD2D-4F68-8FD8-B3D2067F4467> cl_kernels | |
0x109958000 - | 0x109a38ff7 unorm8_rgba.dylib (2.4.5) <A8805102-8A21-3A5E-AE22-63C0DEC8CB6F> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib | |
0x109c12000 - | 0x109c18ff7 com.apple.SymptomReporter (1.0 - 1) <3191E395-6284-3C5F-BDA2-BB061CF00B51> /System/Library/PrivateFrameworks/Symptoms.framework/Frameworks/SymptomReporter.framework/SymptomReporter | |
0x10aa51000 - | 0x10aa63fff com.apple.webcontentfilter.framework (5.1 - 5.1) <9A7E8B12-BDB4-3FB1-9283-48BDF586B624> /System/Library/PrivateFrameworks/WebContentAnalysis.framework/WebContentAnalysis | |
0x10aa79000 - | 0x10ab2cff7 com.apple.NetworkExtension (1.0 - 1) <30A5B116-F7A3-3523-85C8-D457CAB6BB8A> /System/Library/Frameworks/NetworkExtension.framework/NetworkExtension | |
0x10d0a0000 - | 0x10daa5f03 libllvmForJSC.dylib (7600.1.17) <ADD5ED07-2E04-33A5-B0B5-E742D7862FCF> /System/Library/Frameworks/JavaScriptCore.framework/Libraries/libllvmForJSC.dylib | |
0x7fff65678000 - | 0x7fff656ae837 dyld (353.2.1) <4696A982-1500-34EC-9777-1EF7A03E2659> /usr/lib/dyld | |
0x7fff81930000 - | 0x7fff81a60fff com.apple.UIFoundation (1.0 - 1) <8E030D93-441C-3997-9CD2-55C8DFAC8B84> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation | |
0x7fff81a61000 - | 0x7fff81f4dfff com.apple.MediaToolbox (1.0 - 1562.19) <36062C5F-CC37-3F50-8383-07A9C8C75F33> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox | |
0x7fff820af000 - | 0x7fff820b4fff com.apple.DiskArbitration (2.6 - 2.6) <0DFF4D9B-2AC3-3B82-B5C5-30F4EFBD2DB9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration | |
0x7fff820b5000 - | 0x7fff820c3ff7 com.apple.ToneLibrary (1.0 - 1) <3E6D130D-77B0-31E1-98E3-A6052AB09824> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary | |
0x7fff820c4000 - | 0x7fff820d8ff7 com.apple.MultitouchSupport.framework (260.30 - 260.30) <28728A7D-E048-3B14-9932-839A87D381FE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport | |
0x7fff820db000 - | 0x7fff820e3ff7 com.apple.icloud.FindMyDevice (1.0 - 1) <D198E170-3610-3727-BC87-73AD249CA097> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice | |
0x7fff820e4000 - | 0x7fff820e5ff7 com.apple.print.framework.Print (10.0 - 265) <3BC4FE7F-78A0-3E57-8F4C-520E7EFD36FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print | |
0x7fff820e6000 - | 0x7fff820e9fff libCGXCoreImage.A.dylib (772) <6F42EEBA-6FF4-331F-8F8D-37D6B853614D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib | |
0x7fff820ea000 - | 0x7fff822cfff3 libicucore.A.dylib (531.30) <EF0E7544-E317-3550-A962-6AE65E78AF17> /usr/lib/libicucore.A.dylib | |
0x7fff822d0000 - | 0x7fff822d2ff7 com.apple.diagnosticlogcollection (10.0 - 1000) <D7516965-DB40-3235-9D00-C724F7D2BC02> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection | |
0x7fff822d3000 - | 0x7fff82364ff7 libCoreStorage.dylib (471) <5CA37ED3-320C-3469-B4D2-6F045AFE03A1> /usr/lib/libCoreStorage.dylib | |
0x7fff82384000 - | 0x7fff823f2ffb com.apple.Heimdal (4.0 - 2.0) <B852ACA1-4C64-3E2A-A9D3-6D4C80AD9429> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal | |
0x7fff82a5b000 - | 0x7fff82a5cfff com.apple.TrustEvaluationAgent (2.0 - 25) <2D61A2C3-C83E-3A3F-8EC1-736DBEC250AB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent | |
0x7fff82a5d000 - | 0x7fff82a61ff7 com.apple.LoginUICore (3.0 - 3.0) <86C742AF-8F8A-3AD6-AFD3-DEC66815B5C0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore | |
0x7fff82a7e000 - | 0x7fff82ab9fff com.apple.QD (301 - 301) <C4D2AD03-B839-350A-AAF0-B4A08F8BED77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD | |
0x7fff82aba000 - | 0x7fff82e50fff com.apple.CoreFoundation (6.9 - 1151.16) <F2B088AF-A5C6-3FAE-9EB4-7931AF6359E4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation | |
0x7fff82e51000 - | 0x7fff82e6bff3 com.apple.Ubiquity (1.3 - 313) <DF56A657-CC6E-3BE2-86A0-71F07127724C> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity | |
0x7fff82e6c000 - | 0x7fff82ebdff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <AF72B06E-C6C1-3FAE-8B47-AF461CAE0E22> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio | |
0x7fff82ecd000 - | 0x7fff82eeefff com.apple.framework.Apple80211 (10.0 - 1000.57.3) <F64EB1A1-57F3-3ABA-97D0-DB7C926FD07F> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211 | |
0x7fff82ef4000 - | 0x7fff83134ff7 com.apple.AddressBook.framework (9.0 - 1498) <EFCD7F23-4654-3B3F-997B-88054D29D442> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook | |
0x7fff83135000 - | 0x7fff8313bff7 libsystem_networkextension.dylib (167.1.10) <29AB225B-D7FB-30ED-9600-65D44B9A9442> /usr/lib/system/libsystem_networkextension.dylib | |
0x7fff8313c000 - | 0x7fff8313dfff libsystem_secinit.dylib (18) <581DAD0F-6B63-3A48-B63B-917AF799ABAA> /usr/lib/system/libsystem_secinit.dylib | |
0x7fff8314b000 - | 0x7fff8319effb libAVFAudio.dylib (118.3) <CC124063-34DF-39E3-921A-2BA3EA8D6F38> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib | |
0x7fff8319f000 - | 0x7fff831dafff com.apple.Symbolication (1.4 - 56045) <D64571B1-4483-3FE2-BD67-A91360F79727> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication | |
0x7fff831db000 - | 0x7fff831deff7 libdyld.dylib (353.2.1) <19FAF435-C165-3374-9DEF-D7BBA7D61DB6> /usr/lib/system/libdyld.dylib | |
0x7fff831df000 - | 0x7fff83203ff7 com.apple.quartzfilters (1.10.0 - 1.10.0) <1AE50F4A-0098-34E7-B24D-DF7CB94073CE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters | |
0x7fff83204000 - | 0x7fff83278ff3 com.apple.securityfoundation (6.0 - 55126) <E7FB7A4E-CB0B-37BA-ADD5-373B2A20A783> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation | |
0x7fff83279000 - | 0x7fff8330eff7 com.apple.ColorSync (4.9.0 - 4.9.0) <F06733BD-A10C-3DB3-B050-825351130392> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync | |
0x7fff8330f000 - | 0x7fff833a3fff com.apple.ink.framework (10.9 - 213) <8E029630-1530-3734-A446-13353F0E7AC5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink | |
0x7fff833bd000 - | 0x7fff834d4fe7 libvDSP.dylib (512) <52777555-F051-3BC2-A2D2-9645907E836D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib | |
0x7fff834d6000 - | 0x7fff834d9ff7 com.apple.Mangrove (1.0 - 1) <2AF1CAE9-8BF9-33C4-9C1B-123DBAF1522B> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove | |
0x7fff8355f000 - | 0x7fff835cbfff com.apple.framework.CoreWLAN (5.0 - 500.35.2) <ACBAAB0A-BCC7-37CF-AAFB-2DA1733F2682> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN | |
0x7fff835cc000 - | 0x7fff835ccfff com.apple.Cocoa (6.8 - 21) <EAC0EA1E-3C62-3B28-A941-5D8B1E085FF8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa | |
0x7fff835cd000 - | 0x7fff83659fff libsystem_c.dylib (1044.1.2) <C185E862-7424-3210-B528-6B822577A4B8> /usr/lib/system/libsystem_c.dylib | |
0x7fff8365a000 - | 0x7fff836a7ff3 com.apple.CoreMediaIO (601.0 - 4749) <DDB756B3-A281-3791-9744-1F52CF8E5EDB> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO | |
0x7fff836a8000 - | 0x7fff836aeff7 com.apple.XPCService (2.0 - 1) <AA4A5393-1F5D-3465-A417-0414B95DC052> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService | |
0x7fff836af000 - | 0x7fff836c9ff7 com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos | |
0x7fff836ca000 - | 0x7fff836f3ffb libxslt.1.dylib (13) <AED1143F-B848-3E73-81ED-71356F25F084> /usr/lib/libxslt.1.dylib | |
0x7fff83735000 - | 0x7fff83739fff libspindump.dylib (182) <7BD8C0AC-1CDA-3864-AE03-470B50160148> /usr/lib/libspindump.dylib | |
0x7fff8373a000 - | 0x7fff83795fff com.apple.QuickLookFramework (5.0 - 675) <D71CD23B-643B-341B-A890-57FE099B36C7> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook | |
0x7fff83796000 - | 0x7fff83797ff7 libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib | |
0x7fff83798000 - | 0x7fff8387bfff libcrypto.0.9.8.dylib (52) <7208EEE2-C090-383E-AADD-7E1BD1321BEC> /usr/lib/libcrypto.0.9.8.dylib | |
0x7fff8387c000 - | 0x7fff8387dffb libremovefile.dylib (35) <3485B5F4-6CE8-3C62-8DFD-8736ED6E8531> /usr/lib/system/libremovefile.dylib | |
0x7fff8387e000 - | 0x7fff8389cff7 com.apple.addressbook.vCard (9.0 - 1498) <45C2138B-EA52-3576-8C5C-46637E648DF2> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard | |
0x7fff838c1000 - | 0x7fff838ccff7 libkxld.dylib (2782.1.97) <CB1A1B57-54BE-3573-AE0C-B90ED6BAEEE2> /usr/lib/system/libkxld.dylib | |
0x7fff838cd000 - | 0x7fff838ddff7 libbsm.0.dylib (34) <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB> /usr/lib/libbsm.0.dylib | |
0x7fff839ac000 - | 0x7fff839d4ffb libRIP.A.dylib (772) <9262437A-710A-397D-8E34-1CBFEA1FC5E1> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib | |
0x7fff839d5000 - | 0x7fff83a00ff3 libarchive.2.dylib (30) <8CBB4416-EBE9-3574-8ADC-44655D245F39> /usr/lib/libarchive.2.dylib | |
0x7fff83a48000 - | 0x7fff83aa2ff7 com.apple.LanguageModeling (1.0 - 1) <ACA93FE0-A0E3-333E-AE3C-8EB7DE5F362F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling | |
0x7fff83b3b000 - | 0x7fff83b4afff com.apple.LangAnalysis (1.7.0 - 1.7.0) <D1E527E4-C561-352F-9457-E8C50232793C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis | |
0x7fff83e72000 - | 0x7fff83e75fff com.apple.IOSurface (97 - 97) <D4B4D2B2-7B16-3174-9EA6-55E0A10B452D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface | |
0x7fff83e76000 - | 0x7fff83e78fff libsystem_configuration.dylib (699.1.5) <9FBA1CE4-97D0-347E-A443-93ED94512E92> /usr/lib/system/libsystem_configuration.dylib | |
0x7fff83e79000 - | 0x7fff83f17fff com.apple.Metadata (10.7.0 - 916) <DA8A1D18-19FE-37B3-BE12-85C5B0A00736> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata | |
0x7fff83f18000 - | 0x7fff83f40fff libxpc.dylib (559.1.22) <9437C02E-A07B-38C8-91CB-299FAA63083D> /usr/lib/system/libxpc.dylib | |
0x7fff83fe8000 - | 0x7fff8429cff7 com.apple.WebKit (10600 - 10600.1.25) <84496A10-D8E5-3E8C-93B1-98D5AE790922> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit | |
0x7fff842e6000 - | 0x7fff84345ff3 com.apple.AE (681 - 681) <7F544183-A515-31A8-B45F-89A167F56216> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE | |
0x7fff84346000 - | 0x7fff84373ffb com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <3646ECEF-1875-31CD-B614-FBE29A7500EF> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X | |
0x7fff84374000 - | 0x7fff843e3fff com.apple.SearchKit (1.4.0 - 1.4.0) <BFD6D876-36BA-3A3B-9F15-3E2F7DE6E89D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit | |
0x7fff843f4000 - | 0x7fff846c3ff3 com.apple.CoreImage (10.0.33) <6E3DDA29-718B-3BDB-BFAF-F8C201BF93A4> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage | |
0x7fff846c4000 - | 0x7fff848a9267 libobjc.A.dylib (646) <3B60CD90-74A2-3A5D-9686-B0772159792A> /usr/lib/libobjc.A.dylib | |
0x7fff848aa000 - | 0x7fff84b24fff com.apple.CoreData (110 - 526) <AEEDAF00-D38F-3A15-B3C9-73732940CC55> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData | |
0x7fff84b25000 - | 0x7fff84b30ff7 com.apple.speech.synthesis.framework (5.2.6 - 5.2.6) <9434AA45-B6BD-37F7-A866-172196A7F91B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis | |
0x7fff84b31000 - | 0x7fff84b34ff7 com.apple.AppleSystemInfo (3.0 - 3.0) <E54DA0B2-3515-3B1C-A4BD-54A0B02B5612> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo | |
0x7fff84b35000 - | 0x7fff84b42fff com.apple.SpeechRecognitionCore (2.0.32 - 2.0.32) <87F0C88D-502D-3217-8B4A-8388288568BA> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore | |
0x7fff84b43000 - | 0x7fff84b4fff7 com.apple.commonutilities (8.0 - 900) <E5E018A7-FB3C-37A2-9769-49AFAC89FDE8> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities | |
0x7fff854ab000 - | 0x7fff854d2fff com.apple.shortcut (2.12 - 2.12) <66E6B3FE-3726-376E-95A0-40DAAFBE1AE0> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut | |
0x7fff854d3000 - | 0x7fff854f9ff7 com.apple.ChunkingLibrary (2.1 - 163.1) <3514F2A4-38BD-3849-9286-B3B991057742> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary | |
0x7fff854ff000 - | 0x7fff85501ff7 libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib | |
0x7fff8550f000 - | 0x7fff85516fff com.apple.NetFS (6.0 - 4.0) <1581D25F-CC07-39B0-90E8-5D4F3CF84EBA> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS | |
0x7fff85517000 - | 0x7fff85549ff3 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <C6DB0A07-F8E4-3837-BCA9-225F460EDA81> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon | |
0x7fff8554a000 - | 0x7fff85627ff7 com.apple.QuickLookUIFramework (5.0 - 675) <84FEB409-7D7A-35AC-83BE-F79FB293E23E> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI | |
0x7fff85628000 - | 0x7fff856b1fff com.apple.CoreSymbolication (3.1 - 56072) <8CE81C95-49E8-389F-B989-67CC452C08D0> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication | |
0x7fff856b2000 - | 0x7fff86656ffb com.apple.WebCore (10600 - 10600.1.25) <EE07107A-A63D-3077-B863-C82C1E80B56D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore | |
0x7fff86657000 - | 0x7fff8666dff7 libsystem_asl.dylib (267) <F153AC5B-0542-356E-88C8-20A62CA704E2> /usr/lib/system/libsystem_asl.dylib | |
0x7fff8668d000 - | 0x7fff86a9aff7 libLAPACK.dylib (1128) <F9201AE7-B031-36DB-BCF8-971E994EF7C1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib | |
0x7fff86a9b000 - | 0x7fff86aa6ff7 com.apple.AppSandbox (4.0 - 238) <BC5EE1CA-764A-303D-9989-4041C1291026> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox | |
0x7fff86b95000 - | 0x7fff86bc1fff com.apple.framework.SystemAdministration (1.0 - 1.0) <F2A164C7-4813-3F27-ABF7-810A5F4FA51D> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration | |
0x7fff86bc2000 - | 0x7fff86c03fff libGLU.dylib (11.0.7) <8037342E-1ECD-385F-B4C3-545CE97B76AE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib | |
0x7fff86c04000 - | 0x7fff86c18ff7 com.apple.ProtectedCloudStorage (1.0 - 1) <52CFE68A-0663-3756-AB5B-B42195026052> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage | |
0x7fff86c19000 - | 0x7fff86c21fff libsystem_dnssd.dylib (561.1.1) <62B70ECA-E40D-3C63-896E-7F00EC386DDB> /usr/lib/system/libsystem_dnssd.dylib | |
0x7fff86c22000 - | 0x7fff86c25fff com.apple.help (1.3.3 - 46) <CA4541F4-CEF5-355C-8F1F-EA65DC1B400F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help | |
0x7fff86c26000 - | 0x7fff86c2afff libpam.2.dylib (20) <E805398D-9A92-31F8-8005-8DC188BD8B6E> /usr/lib/libpam.2.dylib | |
0x7fff86c64000 - | 0x7fff86c68fff com.apple.CommonPanels (1.2.6 - 96) <F9ECC8AF-D9CA-3350-AFB4-5113A9B789A5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels | |
0x7fff86c69000 - | 0x7fff87192ff7 com.apple.QuartzComposer (5.1 - 325) <2007FD9E-A5CF-361E-A7DD-ACAF976860AD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer | |
0x7fff87193000 - | 0x7fff87286ff7 libJP2.dylib (1231) <58849E48-9CD2-38A1-9D48-FCE630F473EB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib | |
0x7fff87287000 - | 0x7fff87289ff7 libquarantine.dylib (76) <DC041627-2D92-361C-BABF-A869A5C72293> /usr/lib/system/libquarantine.dylib | |
0x7fff8728a000 - | 0x7fff872bbfff libtidy.A.dylib (15.15) <37FC944D-271A-386A-9ADD-FA33AD48F96D> /usr/lib/libtidy.A.dylib | |
0x7fff872bc000 - | 0x7fff872dcfff com.apple.IconServices (47.1 - 47.1) <E83DFE3B-6541-3736-96BB-26DC5D0100F1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices | |
0x7fff872dd000 - | 0x7fff872f6fff com.apple.openscripting (1.4 - 162) <80DFF366-B950-3F79-903F-99DA0FFDB570> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting | |
0x7fff872f7000 - | 0x7fff872f9fff com.apple.loginsupport (1.0 - 1) <35A2A071-606C-39A5-8C11-E4CAF98D934C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport | |
0x7fff872fa000 - | 0x7fff8730cff7 com.apple.ImageCapture (9.0 - 9.0) <7FB65DD4-56B5-35C4-862C-7A2DED991D1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture | |
0x7fff87315000 - | 0x7fff8731cfff libCGCMS.A.dylib (772) <E64DC779-A6CF-3B1F-8E57-C09C0B10670F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib | |
0x7fff8748c000 - | 0x7fff874b1ff7 libPng.dylib (1231) <2D5AC0EE-4056-3F76-97E7-BBD415F072B5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib | |
0x7fff874b2000 - | 0x7fff874cefff com.apple.GenerationalStorage (2.0 - 209.11) <9FF8DD11-25FB-3047-A5BF-9415339B3EEC> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage | |
0x7fff874cf000 - | 0x7fff874d1ff7 libutil.dylib (38) <471AD65E-B86E-3C4A-8ABD-B8665A2BCE3F> /usr/lib/libutil.dylib | |
0x7fff874f7000 - | 0x7fff877a3fff com.apple.GeoServices (1.0 - 982.4.10) <8A7FE04A-2785-30E7-A6E2-DC15D170DAF5> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices | |
0x7fff878cf000 - | 0x7fff878f2ff7 com.apple.idsfoundation (10.0 - 1000) <D0C0714F-B1B0-3D86-BAA8-DACC76121118> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation | |
0x7fff878fc000 - | 0x7fff8792cffb com.apple.GSS (4.0 - 2.0) <D033E7F1-2D34-339F-A814-C67E009DE5A9> /System/Library/Frameworks/GSS.framework/Versions/A/GSS | |
0x7fff8792d000 - | 0x7fff879aeff3 com.apple.CoreUtils (1.0 - 101.1) <45E5E51B-947E-3F2D-BD9C-480E72555C23> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils | |
0x7fff879af000 - | 0x7fff884f0fff com.apple.AppKit (6.9 - 1343.14) <1732C412-257B-340E-8863-B8162D4EB2E2> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit | |
0x7fff884f1000 - | 0x7fff884f5fff libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib | |
0x7fff88546000 - | 0x7fff88549fff com.apple.xpc.ServiceManagement (1.0 - 1) <7E9E6BB7-AEE7-3F59-BAC0-59EAF105D0C8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement | |
0x7fff8854a000 - | 0x7fff8854eff7 libGIF.dylib (1231) <A349BA73-301E-3EDE-8A31-8ACE827C289E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib | |
0x7fff8856b000 - | 0x7fff886f9fff libBLAS.dylib (1128) <497912C1-A98E-3281-BED7-E9C751552F61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib | |
0x7fff886fa000 - | 0x7fff888fdff3 com.apple.CFNetwork (720.0.9 - 720.0.9) <78EE1B88-394F-3BB8-93A6-E068990559EC> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork | |
0x7fff888fe000 - | 0x7fff88a3bfff com.apple.ImageIO.framework (3.3.0 - 1038) <611BDFBA-4BAA-36A8-B7E0-3830F3375E53> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO | |
0x7fff88a53000 - | 0x7fff88b16ff7 libvMisc.dylib (512) <A4E39464-52EA-34CB-9FFE-53E79B3C65F5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib | |
0x7fff88b17000 - | 0x7fff88b17fff com.apple.Accelerate (1.10 - Accelerate 1.10) <227E2491-1DDB-336F-BF83-773CECEC66F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate | |
0x7fff88b18000 - | 0x7fff88b18ff7 libunc.dylib (29) <5676F7EA-C1DF-329F-B006-D2C3022B7D70> /usr/lib/system/libunc.dylib | |
0x7fff88b97000 - | 0x7fff893eeff3 com.apple.CoreGraphics (1.600.0 - 772) <6364CBE3-3635-3A53-B448-9D19EF9FEA96> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics | |
0x7fff893ef000 - | 0x7fff8943bff7 libcups.2.dylib (408) <9CECCDE3-51D7-3028-830C-F58BD36E3317> /usr/lib/libcups.2.dylib | |
0x7fff894c0000 - | 0x7fff894c0fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <A48738CA-5B6F-3D14-97E9-2BFDFC3DCC06> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib | |
0x7fff894c1000 - | 0x7fff894c1fff com.apple.CoreServices (62 - 62) <9E4577CA-3FC3-300D-AB00-87ADBDDA2E37> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices | |
0x7fff894c2000 - | 0x7fff89538fe7 libcorecrypto.dylib (233.1.2) <E1789801-3985-3949-B736-6B3378873301> /usr/lib/system/libcorecrypto.dylib | |
0x7fff89539000 - | 0x7fff8953bfff libCVMSPluginSupport.dylib (11.0.7) <29D775BB-A11D-3140-A478-2A0DA1A87420> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib | |
0x7fff8953c000 - | 0x7fff89545fff com.apple.DisplayServicesFW (2.9 - 372.1) <30E61754-D83C-330A-AE60-533F27BEBFF5> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices | |
0x7fff89546000 - | 0x7fff89638fff libxml2.2.dylib (26) <B834E7C8-EC3E-3382-BC5A-DA38DC4D720C> /usr/lib/libxml2.2.dylib | |
0x7fff89639000 - | 0x7fff89679ff7 com.apple.CloudDocs (1.0 - 280.1) <21D7E10A-99EF-34BE-82D7-29A6F1761DE5> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs | |
0x7fff8972a000 - | 0x7fff8977bff7 com.apple.AppleVAFramework (5.0.31 - 5.0.31) <762E9358-A69A-3D63-8282-3B77FBE0147E> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA | |
0x7fff8979a000 - | 0x7fff89830ffb com.apple.CoreMedia (1.0 - 1562.19) <F79E0E9D-4ED1-3ED1-827A-C3C5377DB1D7> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia | |
0x7fff8988c000 - | 0x7fff89d9fff3 com.apple.JavaScriptCore (10600 - 10600.1.17) <CE5255CC-E13F-3694-B6DD-5285356BFCC0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore | |
0x7fff89da0000 - | 0x7fff89da1ff7 com.apple.AddressBook.ContactsData (9.0 - 1498) <2F7F3C93-9F1E-3E43-851B-F639EF37D552> /System/Library/PrivateFrameworks/ContactsData.framework/Versions/A/ContactsData | |
0x7fff89da2000 - | 0x7fff89dbbff7 com.apple.CFOpenDirectory (10.10 - 187) <0ECA5D80-A045-3A2C-A60C-E1605F3AB6BD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory | |
0x7fff89dbc000 - | 0x7fff89df2ffb com.apple.datadetectors (5.0 - 273) <9E17D22E-1A96-3A4F-8394-F14ED7D862D0> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors | |
0x7fff89df3000 - | 0x7fff8a1cafe7 com.apple.CoreAUC (211.0.0 - 211.0.0) <C8B2470F-3994-37B8-BE10-6F78667604AC> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC | |
0x7fff8a1cb000 - | 0x7fff8a26dfff com.apple.Bluetooth (4.3.0 - 4.3.0f10) <70922125-2A01-37AE-9CB8-D8A9578092E4> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth | |
0x7fff8a293000 - | 0x7fff8a2aeff7 com.apple.aps.framework (4.0 - 4.0) <9955CAFD-D56B-36E9-BB41-6F7F73317EB5> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService | |
0x7fff8a2af000 - | 0x7fff8a2bafdb com.apple.AppleFSCompression (68.1.1 - 1.0) <F30E8CA3-50B3-3B44-90A0-803C5C308BFE> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression | |
0x7fff8a2bb000 - | 0x7fff8a37afff com.apple.backup.framework (1.6 - 1.6) <5C38C168-5E9B-335D-9570-91AF8604BB10> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup | |
0x7fff8a43a000 - | 0x7fff8a44fffb libCGInterfaces.dylib (294.1) <1A6AADE6-09EC-3054-85F9-E6A3607EBA70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib | |
0x7fff8a450000 - | 0x7fff8a4baff7 com.apple.imfoundation (10.0 - 1000) <1810C42E-B06B-385B-9D17-FDB9C9D91E90> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation | |
0x7fff8a4bb000 - | 0x7fff8a4c8fff com.apple.ProtocolBuffer (1 - 225.1) <2D502FBB-D2A0-3937-A5C5-385FA65B3874> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer | |
0x7fff8a626000 - | 0x7fff8a62bffb libheimdal-asn1.dylib (398.1.2) <F9463B34-AAF5-3488-AD0C-85937C81FC5E> /usr/lib/libheimdal-asn1.dylib | |
0x7fff8a6c4000 - | 0x7fff8a6c4fff com.apple.WebKit2 (10600 - 10600.1.25) <32C26838-0090-388F-B5E3-DFB597B9B37B> /System/Library/PrivateFrameworks/WebKit2.framework/Versions/A/WebKit2 | |
0x7fff8a6c5000 - | 0x7fff8a6d1ff7 com.apple.HelpData (2.1.4 - 90) <687682B4-C576-3EAF-B113-D7046AA87D69> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData | |
0x7fff8a6d2000 - | 0x7fff8ab02fff com.apple.vision.FaceCore (3.1.6 - 3.1.6) <C3B823AA-C261-37D3-B4AC-C59CE91C8241> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore | |
0x7fff8ab0f000 - | 0x7fff8ab3cfff com.apple.CoreVideo (1.8 - 145.1) <18DB07E0-B927-3260-A234-636F298D1917> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo | |
0x7fff8ab3d000 - | 0x7fff8ab41ff7 com.apple.TCC (1.0 - 1) <AFC32F8F-BCD5-313C-B66E-5AB8591EC066> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC | |
0x7fff8ab42000 - | 0x7fff8ab48fff libsystem_trace.dylib (72.1.3) <A9E6B7D8-C327-3742-AC54-86C94218B1DF> /usr/lib/system/libsystem_trace.dylib | |
0x7fff8ab6c000 - | 0x7fff8ab77fff libGL.dylib (11.0.7) <C53344AD-8CE6-3111-AB94-BD4CA89ED84E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib | |
0x7fff8ac71000 - | 0x7fff8ad10df7 com.apple.AppleJPEG (1.0 - 1) <9BB3D7DF-630A-3E1C-A124-12D6C4D0DE70> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG | |
0x7fff8ad11000 - | 0x7fff8adccff7 com.apple.DiscRecording (9.0 - 9000.4.1) <F70E600E-9668-3DF2-A3A8-61813DF9E2EE> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording | |
0x7fff8adcd000 - | 0x7fff8adf0fff com.apple.Sharing (328.3 - 328.3) <FDEE49AD-8804-3760-9C14-8D1D10BBEA37> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing | |
0x7fff8adf1000 - | 0x7fff8ae10fff com.apple.CoreDuet (1.0 - 1) <36AA9FD5-2685-314D-B364-3FA4688D86BD> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet | |
0x7fff8ae11000 - | 0x7fff8ae19ff7 com.apple.AppleSRP (5.0 - 1) <01EC5144-D09A-3D6A-AE35-F6D48585F154> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP | |
0x7fff8ae1a000 - | 0x7fff8ae34ff7 libextension.dylib (55) <17514AB2-C503-3D49-A725-EBC1140567A6> /usr/lib/libextension.dylib | |
0x7fff8ae35000 - | 0x7fff8aea6ff7 com.apple.framework.IOKit (2.0.2 - 1050.1.21) <ED3B0B22-AACC-303B-BFC8-20ECD1AF6BA2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit | |
0x7fff8aea7000 - | 0x7fff8aeb4ff7 libxar.1.dylib (254) <CE10EFED-3066-3749-838A-6A15AC0DBCB6> /usr/lib/libxar.1.dylib | |
0x7fff8afce000 - | 0x7fff8b100ff7 com.apple.MediaControlSender (2.0 - 215.10) <8ECF208C-587A-325F-9866-09890D58F1B1> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender | |
0x7fff8b101000 - | 0x7fff8b11bff7 liblzma.5.dylib (7) <1D03E875-A7C0-3028-814C-3C27F7B7C079> /usr/lib/liblzma.5.dylib | |
0x7fff8b11c000 - | 0x7fff8b123ff7 com.apple.phonenumbers (1.1.1 - 105) <AE39B6FE-05AB-3181-BB2A-4D50A8B392F2> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers | |
0x7fff8b124000 - | 0x7fff8b1b2ff7 com.apple.CorePDF (4.0 - 4) <9CD7EC6D-3593-3D60-B04F-75F612CCB99A> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF | |
0x7fff8b1b3000 - | 0x7fff8b1f9ffb libFontRegistry.dylib (134) <01B8034A-45FD-3360-A347-A1896F591363> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib | |
0x7fff8b1fa000 - | 0x7fff8b24efff libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib | |
0x7fff8b269000 - | 0x7fff8b285ff7 libsystem_malloc.dylib (53.1.1) <19BCC257-5717-3502-A71F-95D65AFA861B> /usr/lib/system/libsystem_malloc.dylib | |
0x7fff8b286000 - | 0x7fff8b2edff7 com.apple.datadetectorscore (6.0 - 396.1) <5D348063-1528-3E2F-B587-9E82970506F9> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore | |
0x7fff8b2ee000 - | 0x7fff8b366ff7 com.apple.SystemConfiguration (1.14 - 1.14) <C269BCFD-ACAB-3331-BC7C-0430F0E84817> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration | |
0x7fff8b367000 - | 0x7fff8b395fff com.apple.CoreServicesInternal (221.1 - 221.1) <51BAE6D2-84F3-392A-BFEC-A3B47B80A3D2> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal | |
0x7fff8b396000 - | 0x7fff8b3b3ffb libresolv.9.dylib (57) <26B38E61-298A-3C3A-82C1-3B5E98AD5E29> /usr/lib/libresolv.9.dylib | |
0x7fff8b3b4000 - | 0x7fff8b3c6fff libsasl2.2.dylib (193) <E523DD05-544B-3430-8AA9-672408A5AF8B> /usr/lib/libsasl2.2.dylib | |
0x7fff8b3c7000 - | 0x7fff8b503ffb com.apple.WebKitLegacy (10600 - 10600.1.25) <EE3A7515-AC7B-30D3-A4DC-EB0D36E88E4B> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy | |
0x7fff8b504000 - | 0x7fff8b62bfff com.apple.coreui (2.1 - 305) <BB430677-D1F7-38DD-8F05-70E54352B8B5> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI | |
0x7fff8b62c000 - | 0x7fff8b63afff com.apple.AddressBook.ContactsFoundation (9.0 - 1498) <0BD29957-C30F-376A-B28F-1510F80A9174> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation | |
0x7fff8b645000 - | 0x7fff8b647fff com.apple.EFILogin (2.0 - 2) <F0269EE2-3686-3A8A-8B83-F86974E35E90> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin | |
0x7fff8b64a000 - | 0x7fff8b64cfff com.apple.CoreDuetDebugLogging (1.0 - 1) <9A6E5710-EA99-366E-BF40-9A65EC1B46A1> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging | |
0x7fff8b68f000 - | 0x7fff8b6a1ff7 com.apple.CoreDuetDaemonProtocol (1.0 - 1) <CE9FABB4-1C5D-3F9B-9BB8-5CC50C3E5E31> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol | |
0x7fff8b6a2000 - | 0x7fff8b778ff3 com.apple.DiskImagesFramework (10.10 - 389.1) <7DE2208C-BD55-390A-8167-4F9F11750C4B> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages | |
0x7fff8b77a000 - | 0x7fff8b78bfff libcmph.dylib (1) <46EC3997-DB5E-38AE-BBBB-A035A54AD3C0> /usr/lib/libcmph.dylib | |
0x7fff8b78c000 - | 0x7fff8b790fff libCoreVMClient.dylib (79) <FC4E08E3-749E-32FF-B5E9-211F29864831> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib | |
0x7fff8b791000 - | 0x7fff8b8a9ffb com.apple.CoreText (352.0 - 454.1) <AB07DF12-BB1F-3275-A8A3-45F14BF872BF> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText | |
0x7fff8b8aa000 - | 0x7fff8b92cfff com.apple.PerformanceAnalysis (1.0 - 1) <2FC0F303-B672-3E64-A978-AB78EAD98395> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis | |
0x7fff8b92d000 - | 0x7fff8b93aff7 libbz2.1.0.dylib (36) <2DF83FBC-5C08-39E1-94F5-C28653791B5F> /usr/lib/libbz2.1.0.dylib | |
0x7fff8b93b000 - | 0x7fff8b952ff7 libLinearAlgebra.dylib (1128) <E78CCBAA-A999-3B65-8EC9-06DB15E67C37> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib | |
0x7fff8b953000 - | 0x7fff8b95cff7 libsystem_notify.dylib (133.1.1) <61147800-F320-3DAA-850C-BADF33855F29> /usr/lib/system/libsystem_notify.dylib | |
0x7fff8c1f1000 - | 0x7fff8c2e5ff7 libFontParser.dylib (134) <506126F8-FDCE-3DE1-9DCA-E07FE658B597> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib | |
0x7fff8c2e6000 - | 0x7fff8c2e6ff7 libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib | |
0x7fff8c2e7000 - | 0x7fff8c5ceffb com.apple.CoreServices.CarbonCore (1108.1 - 1108.1) <55A16172-ACC0-38B7-8409-3CB92AF33973> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore | |
0x7fff8c5cf000 - | 0x7fff8c5e5ff7 com.apple.CoreMediaAuthoring (2.2 - 951) <B5E5ADF2-BBE8-30D9-83BC-74D0D450CF42> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring | |
0x7fff8c5e6000 - | 0x7fff8c5e8fff com.apple.OAuth (25 - 25) <EE765AF0-2BB6-3689-9EAA-689BF1F02A0D> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth | |
0x7fff8c5e9000 - | 0x7fff8c851ffb com.apple.security (7.0 - 57031.1.35) <96141D1F-614E-32C4-8AC2-F47481F23F43> /System/Library/Frameworks/Security.framework/Versions/A/Security | |
0x7fff8c852000 - | 0x7fff8c889ffb com.apple.LDAPFramework (2.4.28 - 194.5) <4CFE8010-CE3F-35EC-90BA-529B74321029> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP | |
0x7fff8c88a000 - | 0x7fff8cbbdfff libmecabra.dylib (666) <2CE5540A-D412-3D53-9E11-86C24D61713B> /usr/lib/libmecabra.dylib | |
0x7fff8cbbe000 - | 0x7fff8cbedfff com.apple.securityinterface (10.0 - 55058) <21F38170-2D3D-3FA2-B0EC-379482AFA5E4> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface | |
0x7fff8cc30000 - | 0x7fff8cc54fff com.apple.speech.LatentSemanticMappingFramework (2.11.6 - 2.11.6) <5AB4EF58-829E-382D-9E4E-BCD2085C47CC> /System/Library/Frameworks/LatentSemanticMapping.framework/Versions/A/LatentSemanticMapping | |
0x7fff8cce1000 - | 0x7fff8cd0cfff com.apple.DictionaryServices (1.2 - 229) <6789EC43-CADA-394D-8FE8-FC3A2DD136B9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices | |
0x7fff8cd0d000 - | 0x7fff8ce4ffff libsqlite3.dylib (168) <7B580EB9-9260-35FE-AE2F-276A2C242BAB> /usr/lib/libsqlite3.dylib | |
0x7fff8ce5a000 - | 0x7fff8ce6dff7 com.apple.CoreBluetooth (1.0 - 1) <FA9B43B3-E183-3040-AE25-66EF9870CF35> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth | |
0x7fff8ce6e000 - | 0x7fff8d0e8ff3 com.apple.RawCamera.bundle (6.00 - 761) <056E2E1D-6682-354E-9666-7E4935653D47> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera | |
0x7fff8d0e9000 - | 0x7fff8d135fff com.apple.corelocation (1486.17 - 1615.21) <DB68CEB9-0D51-3CB9-86A4-B0400CE6C515> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation | |
0x7fff8d136000 - | 0x7fff8d138fff libRadiance.dylib (1231) <746E9989-E89C-3027-A418-5F99CE131C93> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib | |
0x7fff8d152000 - | 0x7fff8d480ff7 com.apple.Foundation (6.9 - 1151.16) <18EDD673-A010-3E99-956E-DA594CE1FA80> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation | |
0x7fff8d72d000 - | 0x7fff8d734ff7 libcompiler_rt.dylib (35) <BF8FC133-EE10-3DA6-9B90-92039E28678F> /usr/lib/system/libcompiler_rt.dylib | |
0x7fff8d735000 - | 0x7fff8d782fff com.apple.ImageCaptureCore (6.0 - 6.0) <93B4D878-A86B-3615-8426-92E4C79F8482> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore | |
0x7fff8d7e3000 - | 0x7fff8d860fff com.apple.CoreServices.OSServices (640.3 - 640.3) <28445162-08E9-3E24-84E4-617CE5FE1367> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices | |
0x7fff8d861000 - | 0x7fff8d862ff7 libodfde.dylib (22) <52D0ABCD-F464-362C-86EA-ACA10993F556> /usr/lib/libodfde.dylib | |
0x7fff8d863000 - | 0x7fff8d863fff com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices | |
0x7fff8d864000 - | 0x7fff8d891fff com.apple.Accounts (113 - 113) <3145FCC2-D297-3DD1-B74B-9E7DBB0EE33C> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts | |
0x7fff8d892000 - | 0x7fff8d984ff7 libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib | |
0x7fff8d985000 - | 0x7fff8d9ceff3 com.apple.HIServices (1.22 - 519) <59D78E07-C3F1-3272-88F1-876B836D5517> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices | |
0x7fff8da48000 - | 0x7fff8da4dff7 libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib | |
0x7fff8da4e000 - | 0x7fff8da94ff7 libauto.dylib (186) <A260789B-D4D8-316A-9490-254767B8A5F1> /usr/lib/libauto.dylib | |
0x7fff8da95000 - | 0x7fff8dacdfff com.apple.RemoteViewServices (2.0 - 99) <C9A62691-B0D9-34B7-B71C-A48B5F4DC553> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices | |
0x7fff8dace000 - | 0x7fff8db29fff libTIFF.dylib (1231) <ACC9ED11-EED8-3A23-B452-3F40FF7EF435> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib | |
0x7fff8db2a000 - | 0x7fff8dc4bfff com.apple.LaunchServices (644.10 - 644.10) <0B1C68BC-0AEB-38E2-ABC8-E92728FEC475> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices | |
0x7fff8dc4c000 - | 0x7fff8dc69fff libsystem_kernel.dylib (2782.1.97) <93E0E0A9-75B6-3904-BB4E-4BC7C05F4B6B> /usr/lib/system/libsystem_kernel.dylib | |
0x7fff8dc84000 - | 0x7fff8dc8cfff libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib | |
0x7fff8dc8d000 - | 0x7fff8dcc5ffb libsystem_network.dylib (411) <C0B2313D-47BE-38A9-BEE6-2634A4F5E14B> /usr/lib/system/libsystem_network.dylib | |
0x7fff8dcc6000 - | 0x7fff8dd2bff7 com.apple.ids (10.0 - 1000) <12E5717E-8D63-3B70-BB46-A60AFB02CCAE> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS | |
0x7fff8dd92000 - | 0x7fff8ded6ff7 com.apple.QTKit (7.7.3 - 2890) <6F6CD79F-CFBB-3FE4-82C6-47991346FB17> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit | |
0x7fff8ded7000 - | 0x7fff8df0aff7 com.apple.MediaKit (16 - 757) <345EDAFE-3E39-3B0F-8D84-54657EC4396D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit | |
0x7fff8df0b000 - | 0x7fff8df5aff7 com.apple.opencl (2.4.2 - 2.4.2) <6AE26E08-6EFC-3E1B-B202-EFA9C3E5B9D4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL | |
0x7fff8df5b000 - | 0x7fff8dfecfff com.apple.cloudkit.CloudKit (259.2.3 - 259.2.3) <6F955140-D522-32B3-B34B-BD94C5D94E7A> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit | |
0x7fff8dfed000 - | 0x7fff8e019fff libsandbox.1.dylib (358.1.1) <9A00BD06-579F-3EDF-9D4C-590DFE54B103> /usr/lib/libsandbox.1.dylib | |
0x7fff8e01a000 - | 0x7fff8e020fff com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <BB2D573F-0A01-379F-A2BA-3C454EDCB111> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition | |
0x7fff8e021000 - | 0x7fff8e05eff3 com.apple.bom (14.0 - 193.6) <3CE5593D-DB28-3BFD-943E-6261006FA292> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom | |
0x7fff8e05f000 - | 0x7fff8e064ff7 com.apple.MediaAccessibility (1.0 - 61) <00A3E0B6-79AC-387E-B282-AADFBD5722F6> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility | |
0x7fff8e065000 - | 0x7fff8e065fff libOpenScriptingUtil.dylib (162) <EFD79173-A9DA-3AE6-BE15-3948938204A6> /usr/lib/libOpenScriptingUtil.dylib | |
0x7fff8e07e000 - | 0x7fff8e088fff com.apple.IntlPreferences (2.0 - 150.1) <F2DE1784-F780-3E3F-A626-D9CBD38F20EE> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences | |
0x7fff8e089000 - | 0x7fff8e091ffb libcopyfile.dylib (118.1.2) <0C68D3A6-ACDD-3EF3-991A-CC82C32AB836> /usr/lib/system/libcopyfile.dylib | |
0x7fff8e092000 - | 0x7fff8e242ff7 com.apple.QuartzCore (1.10 - 361.11) <7382E4A9-10B0-3877-B9D7-FA84DC71BA55> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore | |
0x7fff8e243000 - | 0x7fff8e244fff libSystem.B.dylib (1213) <DA954461-EC6A-3DF0-8551-6FC810627627> /usr/lib/libSystem.B.dylib | |
0x7fff8e2c3000 - | 0x7fff8e2e8ff7 libJPEG.dylib (1231) <35F13BD9-AA92-3510-B5BB-420DA15AE7F2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib | |
0x7fff8e376000 - | 0x7fff8e378ffb libCGXType.A.dylib (772) <7CB71BC6-D8EC-37BC-8243-41BAB086FAAA> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib | |
0x7fff8e485000 - | 0x7fff8e485fff com.apple.quartzframework (1.5 - 1.5) <4944127A-F319-3689-AAEC-58591D3CAC07> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz | |
0x7fff8e486000 - | 0x7fff8e49bfff com.apple.ToneKit (1.0 - 1) <CA375645-8DE1-3DE8-A2E0-0537849DF59B> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit | |
0x7fff8e49c000 - | 0x7fff8e4a4fe7 libcldcpuengine.dylib (2.4.5) <DF810F9A-1755-3283-82C3-D8192BCD8016> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib | |
0x7fff8e4be000 - | 0x7fff8e4c7fff libsystem_pthread.dylib (105.1.4) <26B1897F-0CD3-30F3-B55A-37CB45062D73> /usr/lib/system/libsystem_pthread.dylib | |
0x7fff8e4ca000 - | 0x7fff8e518fff libcurl.4.dylib (83.1.2) <337A1FF8-E8B1-3173-9F29-C0D4C851D8E1> /usr/lib/libcurl.4.dylib | |
0x7fff8e519000 - | 0x7fff8e559ff7 libGLImage.dylib (11.0.7) <7CBCEB4B-D22F-3116-8B28-D1C22D28C69D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib | |
0x7fff8e70a000 - | 0x7fff8e732fff libsystem_info.dylib (459) <B85A85D5-8530-3A93-B0C3-4DEC41F79478> /usr/lib/system/libsystem_info.dylib | |
0x7fff8e733000 - | 0x7fff8e763fff libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib | |
0x7fff8e764000 - | 0x7fff8e78ffff libc++abi.dylib (125) <88A22A0F-87C6-3002-BFBA-AC0F2808B8B9> /usr/lib/libc++abi.dylib | |
0x7fff8e790000 - | 0x7fff8e79bff7 com.apple.DirectoryService.Framework (10.10 - 187) <813211CD-725D-31B9-ABEF-7B28DE2CB224> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService | |
0x7fff8e79c000 - | 0x7fff8ebeffc7 com.apple.vImage (8.0 - 8.0) <33BE7B31-72DB-3364-B37E-C322A32748C5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage | |
0x7fff8ebf0000 - | 0x7fff8ef5bfff com.apple.VideoToolbox (1.0 - 1562.19) <C08228FE-FA1E-394C-98CB-2AFD8E566C3F> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox | |
0x7fff8f1ed000 - | 0x7fff8f1f9ff7 com.apple.OpenDirectory (10.10 - 187) <1D0066FC-1DEB-381B-B15C-4C009E0DF850> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory | |
0x7fff8f1fa000 - | 0x7fff8f1ffff7 libunwind.dylib (35.3) <BE7E51A0-B6EA-3A54-9CCA-9D88F683A6D6> /usr/lib/system/libunwind.dylib | |
0x7fff8f200000 - | 0x7fff8f200fff com.apple.Carbon (154 - 157) <6E3AEB9D-7643-36BE-A7E5-D08886649257> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon | |
0x7fff8f201000 - | 0x7fff8f225ff7 com.apple.facetimeservices (10.0 - 1000) <52EE049F-36E3-35C8-9304-7878AF7AC241> /System/Library/PrivateFrameworks/FTServices.framework/Versions/A/FTServices | |
0x7fff8f226000 - | 0x7fff8f22dfff com.apple.network.statistics.framework (1.2 - 1) <61B311D1-7F15-35B3-80D4-99B8BE90ACD9> /System/Library/PrivateFrameworks/NetworkStatistics.framework/Versions/A/NetworkStatistics | |
0x7fff8f242000 - | 0x7fff8f253ff7 libz.1.dylib (55) <88C7C7DE-04B8-316F-8B74-ACD9F3DE1AA1> /usr/lib/libz.1.dylib | |
0x7fff8f254000 - | 0x7fff8f265ff7 libsystem_coretls.dylib (35.1.2) <EBBF7EF6-80D8-3F8F-825C-B412BD6D22C0> /usr/lib/system/libsystem_coretls.dylib | |
0x7fff8f266000 - | 0x7fff8f27bff7 com.apple.AppContainer (4.0 - 238) <9481F305-359A-33E6-93F1-89A25FA14E00> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer | |
0x7fff8f27c000 - | 0x7fff8f57efff com.apple.HIToolbox (2.1.1 - 756) <9DD121B5-B7EB-3C43-8155-61A4417F8E9A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox | |
0x7fff8f57f000 - | 0x7fff8f5e6ff7 com.apple.framework.CoreWiFi (3.0 - 300.4) <19269C1D-EB29-384A-83F3-7DDDEB7D9DAD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi | |
0x7fff8f882000 - | 0x7fff8f88dff7 libcsfde.dylib (471) <797691FA-FC0A-3A95-B6E8-BDB75AEAEDFD> /usr/lib/libcsfde.dylib | |
0x7fff8f88e000 - | 0x7fff8f9f9ff7 com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <5C6DBEB4-F2EA-3262-B9FC-AFB89404C1DA> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox | |
0x7fff9039f000 - | 0x7fff90609fff com.apple.imageKit (2.6 - 838) <AFFC0062-F9E0-3F36-B321-D90B7E9CB785> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit | |
0x7fff9066e000 - | 0x7fff90670ff7 libsystem_sandbox.dylib (358.1.1) <DB9962EF-8898-31CC-9B87-E01F8CE74C9D> /usr/lib/system/libsystem_sandbox.dylib | |
0x7fff90671000 - | 0x7fff9067cfff libcommonCrypto.dylib (60061) <D381EBC6-69D8-31D3-8084-5A80A32CB748> /usr/lib/system/libcommonCrypto.dylib | |
0x7fff9067d000 - | 0x7fff90687ff7 com.apple.CrashReporterSupport (10.10 - 629) <EC97EA5E-3190-3717-A4A9-2F35A447E7A6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport | |
0x7fff90688000 - | 0x7fff906c1fff com.apple.AirPlaySupport (2.0 - 215.10) <E4159036-4C38-3F28-8AF3-4F074DAF01AC> /System/Library/PrivateFrameworks/AirPlaySupport.framework/Versions/A/AirPlaySupport | |
0x7fff9075b000 - | 0x7fff90764ff3 com.apple.CommonAuth (4.0 - 2.0) <F4C266BE-2E0E-36B4-9DE7-C6B4BF410FD7> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth | |
0x7fff90765000 - | 0x7fff90767ff7 com.apple.SecCodeWrapper (4.0 - 238) <F450AB10-B0A4-3B55-A1B9-563E55C99333> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper | |
0x7fff90771000 - | 0x7fff90773ff7 com.apple.securityhi (9.0 - 55006) <B1E09986-7AF0-3BD1-BAA1-B5514DFB7CD1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI | |
0x7fff90774000 - | 0x7fff9078eff7 com.apple.AppleVPAFramework (1.0.30 - 1.0.30) <D47A2125-C72D-3298-B27D-D89EA0D55584> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA | |
0x7fff9078f000 - | 0x7fff907b9ff7 libdispatch.dylib (442.1.4) <502CF32B-669B-3709-8862-08188225E4F0> /usr/lib/system/libdispatch.dylib | |
0x7fff90835000 - | 0x7fff90839fff libsystem_stats.dylib (163.1.4) <1DB04436-5974-3F16-86CC-5FF5F390339C> /usr/lib/system/libsystem_stats.dylib | |
0x7fff9083a000 - | 0x7fff90887ff3 com.apple.print.framework.PrintCore (10.0 - 451) <3CA58254-D14F-3913-9DFB-CAC499570CC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore | |
0x7fff90888000 - | 0x7fff90889fff libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib | |
0x7fff908d9000 - | 0x7fff908e1fff libMatch.1.dylib (24) <C917279D-33C2-38A8-9BDD-18F3B24E6FBD> /usr/lib/libMatch.1.dylib | |
0x7fff9093f000 - | 0x7fff909e5fff com.apple.PDFKit (3.0 - 3.0) <C55D8F39-561D-32C7-A701-46F76D6CC151> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit | |
0x7fff90a5b000 - | 0x7fff90a64fff libGFXShared.dylib (11.0.7) <EC449E3A-D9D2-3494-8B6C-DEB7B11EEDAB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib | |
0x7fff90a65000 - | 0x7fff90a6fff7 com.apple.NetAuth (5.0 - 5.0) <B9EC5425-D38D-308C-865F-207E0A98BAC7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth | |
0x7fff90a70000 - | 0x7fff90a72fff com.apple.marco (10.0 - 1000) <ECD31951-F96E-3F5C-B468-729BBEBDCCE3> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco | |
0x7fff90a73000 - | 0x7fff90aa3ff3 com.apple.CoreAVCHD (5.7.5 - 5750.4.1) <3E51287C-E97D-3886-BE88-8F6872400876> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD | |
0x7fff90aa4000 - | 0x7fff90aa4ff7 liblaunch.dylib (559.1.22) <8A988924-8BE7-35FE-BF7D-322E90EFE49E> /usr/lib/system/liblaunch.dylib | |
0x7fff90aa5000 - | 0x7fff90ab3ff7 com.apple.opengl (11.0.7 - 11.0.7) <B5C4DF85-37BD-3984-98D1-90A5043DA984> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL | |
0x7fff90ab4000 - | 0x7fff90acfff7 libCRFSuite.dylib (34) <D64842BE-7BD4-3D0C-9842-1D202F7C2A51> /usr/lib/libCRFSuite.dylib | |
0x7fff90ad0000 - | 0x7fff90ad0fff com.apple.audio.units.AudioUnit (1.12 - 1.12) <76EF1C9D-DEA4-3E55-A134-4099B2FD2CF2> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit | |
0x7fff90af9000 - | 0x7fff90afafff liblangid.dylib (117) <B54A4AA0-2E53-3671-90F5-AFF711C0EB9E> /usr/lib/liblangid.dylib | |
0x7fff90b3c000 - | 0x7fff90b76ffb com.apple.DebugSymbols (115 - 115) <6F03761D-7C3A-3C80-8031-AA1C1AD7C706> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols | |
0x7fff90c89000 - | 0x7fff90de7ff3 com.apple.avfoundation (2.0 - 889.10) <4D1735C4-D055-31E9-8051-FED29F41F4F6> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation | |
0x7fff90e33000 - | 0x7fff90ea7fff com.apple.ApplicationServices.ATS (360 - 375) <62828B40-231D-3F81-8067-1903143DCB6B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS | |
0x7fff91120000 - | 0x7fff91128ffb com.apple.CoreServices.FSEvents (1210 - 1210) <782A9C69-7A45-31A7-8960-D08A36CBD0A7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents | |
0x7fff91129000 - | 0x7fff91238ffb com.apple.desktopservices (1.9 - 1.9) <6EDAC73F-C42C-3FF7-B67D-FCCA1CFC5405> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv |
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 2 | |
thread_create: 0 | |
thread_set_state: 0 |
Calls made by this process:
task_for_pid: 0 | |
Calls made by all processes on this machine:
task_for_pid: 1293 | |
VM Region Summary:
ReadOnly portion of Libraries: Total=275.6M resident=185.3M(67%) swapped_out_or_unallocated=90.2M(33%)
Writable regions: Total=1.2G written=46.8M(4%) resident=77.5M(7%) swapped_out=0K(0%) unallocated=1.1G(93%)
REGION TYPE | VIRTUAL | |
Activity Tracing | 2048K | |
CG backing stores | 7820K | |
CG image | 300K | |
CG shared images | 496K | |
CoreAnimation | 10.1M | |
CoreImage | 72K | |
CoreUI image data | 252K | |
Foundation | 4K | |
Image IO | 716K | |
JS JIT generated code | 256.0M | |
JS JIT generated code (reserved) | 768.0M | reserved VM address space (unallocated) |
JS garbage collector | 4928K | |
Kernel Alloc Once | 8K | |
MALLOC | 88.7M | |
MALLOC (admin) | 32K | |
Memory Tag 242 | 12K | |
Memory Tag 251 | 40K | |
OpenCL | 52K | |
STACK GUARD | 56.0M | |
Stack | 13.1M | |
VM_ALLOCATE | 17.2M | |
WebKit Malloc | 19.8M | |
__DATA | 28.3M | |
__IMAGE | 528K | |
__LINKEDIT | 80.0M | |
__TEXT | 195.6M | |
__UNICODE | 544K | |
mapped file | 98.6M | |
shared memory | 4K | |
TOTAL | 1.6G | |
TOTAL, minus reserved VM space | 880.9M |
Model: iMac7,1, BootROM IM71.007A.B03, 2 processors, Intel Core 2 Duo, 2.4 GHz, 4 GB, SMC 1.20f4
Graphics: ATI Radeon HD 2600 Pro, ATI,RadeonHD2600, PCIe, 256 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR2 SDRAM, 667 MHz, 0x7F98000000000000, 0x393930353239352D3035352E4130304C4600
Memory Module: BANK 1/DIMM1, 2 GB, DDR2 SDRAM, 667 MHz, 0x7F98000000000000, 0x393930353239352D3035352E4130304C4600
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (5.10.131.36.16)
Bluetooth: Version 4.3.0f10 14890, 3 services, 26 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: Hitachi HDT725032VLA360, 320.07 GB
Parallel ATA Device: PIONEER DVD-RW DVR-K06A
USB Device: Keyboard Hub
USB Device: Apple Optical USB Mouse
USB Device: Apple Keyboard
USB Device: eReader-3.12.1
USB Device: Built-in iSight
USB Device: Bluetooth USB Host Controller
USB Device: IR Receiver
Thunderbolt Bus:
Hi Sharad!
Thanks for your reply.
We weren't able to reproduce this error with the sample ebooks provided on the Adobe website.
However, we've identified a number of titles through our Overdrive service that will cause the error repeatedly when the acsm file is tried. In each case, the .acsm file was saved on the local machine and not on a flash or network share.
The titles are:
Unsung Hero by Suzanne Brockman
A Door in the River by Inger Ash Wolfe (I currently have access to a copy for testing)
The Narrow Road to the Deep North by Richard Flanagan
There are more titles involved but I do not yet have complete reports of all of them. Also, not every .acsm file is affected. For example, The Body in the Kelp by Katherine Page Hall was opened successfully for a user when A Door in the River caused a crash.
Similar to the report by lisal12691957 two of my three customers were using Kobo devices and the Kobo device was plugged in at the time of opening the .acsm files.
Thanks for the additional details.
Would you be able to take up one of these machines and then un-install Adobe Digital Editions and then re-install ADE 4.0 again and then test it to check if the issue persists.
You may follow the steps available on the below link to install ADE 4.0 - Can't install Adobe Digital Editions 4.0
Sharad
Hello Sharad,
I have managed to re-create this issue on my MacBook Air with one of the titles I identified (A Door in the River by Inger Ash Wolfe) and I've tried the following actions.
First I tried:
0. Clearing browser cache
1. Uninstalling Adobe Digital Editions 4.0.3 as you suggested
2. Reinstalling Adobe Digital Editons 4.0.3
ADE still crashed with the same error ("ADE quit unexpectedly" - BAD_ACCESS) when I opened a fresh .acsm file for that title from the local storage.
Next I tried:
1. Deauthorizing ADE
2. Uninstalling ADE application
3. Deleting the folders in ~/Library/Application Support/Adobe
4. Reinstalling
5. Re-authorizing
Same result as above with newly downloaded .acsm file - crashing.
I re-tried these steps after updating to Mac OS 10.10.3 - same result with the crash and error.
I have recorded crash output logs for these various attempts - please let me know if I should zip them up for you to have a look at.
Out of curiosity I tried some other titles from the same collection:
These titles caused the same crashing behaviour:
Headed for Trouble by Suzanne Brockmann
I could not reproduce this behaviour for the above titles on my Windows 7, 64 Bit machine with ADE 4.0.3.
These titles (randomly selected or following the same author pattern) were not causing crashing behaviour:
Do or Die by Suzanne Brockmann
The BabySitter's Mary Anne and Camp BSC by Ann M. Martin
Gravity's Rainbow, Domination, and Freedom by Luc Herman
What do you suggest next?
lisal12691957 thanks for your kind words and your suggestions! If you or jwenisch are willing to share the specific Overdrive titles involved that you've had trouble with I can check them out to see if the same behaviour results in our collection but there is definitely no pressure to if you'd like to keep your reading preferences private. I will be in contact with Overdrive about what I've learned so far.
Holly
success. ADE 4.0 is to be avoided. It crashed after my solution.
The solution is trash the activation.dat preference file.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see Access hidden library files | Mac OS 10.7 and later.
I reinstalled ADE 3.0 and life is good. The same acsm file that crashed ADE 4.0 works fine on 3.0.
The Error getting License. License Server Communication Problem: E_ACT_NOT_READY
on yosemite was bogus.
Hi derekdokoto,
Thanks for sharing this workaround! ADE 3.0 is working for me after following your steps, so I will keep using this until 4.0 gets a fix. If anybody else is looking for it, the download is here: Adobe Digital Editions downloads
Jeremy
Thanks--deleting the activation.dat and reverting to 3.0 worked for us. Our Kobo is a paperweight no longer! I think 4.x needs a little more time in the oven Adobe...
Hi Holly,
The OverDrive book I'm having trouble with (and the only one I've tried/borrowed) is Slaughterhouse-Five.
Jeremy
eplholly‌
I'm running 10.10, which is different from your other customers. I see that 10.10.3 is available--perhaps I'll run the update and see if it makes a difference. I see in other threads that some individuals have had success reverting to ADE 3.0, and others all the way back to 1.7.2.
Did any of your customers try to resolve the issue by using a PC? Does the issue exist over there too?
PS--If my guess is correct, you work for a pretty darn good library. The fact you are engaging Adobe directly on behalf of your customers speaks volumes. Congrats on the award--well deserved.
Answering my own question--this does not work in Windows either.
Win 7 Ultimate, 64bit SP1. Newest ADE 4.0.3. Fresh install. Exact same behaviour--can read CuckoosCalling9780316206860.acsm on the PC, but transferring to the Kobo results in the following, copied in it's entirety for the other poor souls trying to find an answer to this debacle.
Oops! This document couldn't be opened
This document is protected by Adobe Digital Rights Management (DRM) and is not currently authorized for use with your Adobe ID. Please sign-in with the authorized Adobe ID and try again. www.kobo.com/help
OK
I'm running into this issue as well. I just installed ADE 4.0.3 this morning for the first time on my Mac version 10.10.2. I downloaded an ACSM file from my library's OverDrive site, and ADE crashes both when trying to open that file and when trying to copy the file to my connected Nook device. I tried uninstalling and reinstalling ADE, as well as rebooting my Mac.
I don't have this problem with books downloaded from Adobe's Sample eBook Library. Based on other user's posting on these forums, it sounds like the issue is specific to books with DRM or perhaps even specific to books downloaded from OverDrive?
Let me know if I can provide any additional information to help. I would love to see this issue resolved ASAP; this is my first attempt to borrow eBooks from my library, and it seems to be impossible for me as long as this issue exists.
Hello all,
I received a follow up message from Adobe staff on this issue - this issue seems to have been addressed in the latest release of ADE 4.0.3: 4.0.3.114137.
I downloaded this release from Adobe's download page and so far I have not experienced any crashes on the Mac (OSX 10.10.3) with the titles I listed above that were crashing before. jwenisch‌ I am still waiting on hold for Slaughterhouse-Five and haven't been able to test that title yet but I suspect it will work too now.
Holly
Thanks Holly for the confirmation that it is working for you post the update.
I would request you all to please install the latest version build for Adobe Digital Edition from - Download | Adobe Digital Editions and then test if it fixes the issue for you and let us know in case you face any issues.
Sharad
Thanks for the info, Holly! I downloaded the latest version, and it seems to be working for me. I no longer have Slaughterhouse-Five checked out (and it's unavailable now), but I checked out a different book from the same OverDrive site, and it both opens from ADE and copies to my Nook through ADE.
Thanks for the fix, Adobe!
