Doesn't enter info
Nov 21, 2007 Nov 21, 2007
I need the following to enter info into the database if information is in the InsertRecord2 query. It acts like it is passing but it only enters the information entered into the first InsertRecord query. Can anyone tell me what I am missing?
Advanced techniques
441
Guest
Please post the relevant code.
Sorry, I thought that I had -
<cftransaction>
<cfquery name="InsertRecord" datasource="NBProdReports">
Insert Into TblMasterTrans (Time_Spent, Date_Opened) Values (#form.Time_Spent#, '#form.Date_Opened#')
</cfquery>
<cfquery name="InsertRecord1" datasource="NBProdReports">
Insert Into TblContractInfo_SubMenuTable (Task_Number, User_ID, Contract_Number,
Transaction_Type , Num_Checks_Trans , Notes)
SELECT MAX(TblMasterTrans.Task_Number),'#form.UserID#','#form.Contract_Number#',
'#form.Trans_Type#','#form.Num_Checks_Trans#',
<cfqueryparam value="#FORM.Notes#"
null="yes">
From TblMasterTrans
</cfquery>
<cfif IsDefined("form.Trans_Type2")>
<cfelse>
<cfif len(trim(form.Trans_Type2)) gt 0>
<cfquery name="InsertRecord2" datasource="NBProdReports">
Transaction_Type , Num_Checks_Trans)
'#form.Trans_Type2#','#form.Num_Checks_Trans2#',
From TblMasterTrans
</cfquery>
</cfif>
</cfif>
</cftransaction>
> <cfelse>
here is your problem if your form.Trans_Type2 is a textbox, which it
looks like it is.
the below code will NEVER run because a textbox is ALWAYS defined, even
if it is blank.
so the <cfelse> part will never fire.
> Contract_Number,
> SELECT
> From TblMasterTrans
> </cfquery>
> </cfif>
> </cfif>
> </cftransaction>
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
Nov 23, 2007 Nov 23, 2007
Any suggestions how we can get around this? The Trans_Type2 has to be a text because the options are pulling from a table in the database.
Guest
Simply delete these two lines of code:
<cfelse>
The next line of code, <cfif len(trim(form.Trans_Type2)) gt 0>, is sufficient to cause the block to execute if there is anything in the text box.
Of course, you will want to delete the corresponding </CFIF> at the bottom.
We have tried removing those lines but then when you try to submit the form, it says page cannot be displayed. We do have debugging turned on on the admin side of the server. Any further suggestions? Could this be an issue with the database?
Guide ,
Nov 25, 2007 Nov 25, 2007
Are you trying to increment the value? ie MAX(Number) + 1?
Disable friendly http error messages
http://support.microsoft.com/kb/294807
> '#form.Num_Checks_Trans2#' (, comma here)
> From TblMasterTrans
Remove the extra comma between the last column and the FROM clause
Guest
Nov 24, 2007 Nov 24, 2007
Copy and paste the error message, please.
Documentation
