i can not delete files to clean up existing files. I can from my phone but not my PC
Hi hugob,
You should still be able to delete files from your Acrobat.com account (and receive a "file delete" confirmation message when you do. If that's not the case, please clear the cache, and then log back in to https://cloud.acrobat.com/files. When you select a file to delete, you'll see a list of options across the top of the file list--on the far right, you'll see the Delete option.
Best,
Sara
Hi chrisb64054279,
Are you referring to files stored in your Acrobat.com online account at https://cloud.acrobat.com/files? If so, what happens when you try to delete the files? Are you receiving an error message?
Please provide a few more details about the issue that you're encountering, including what operating system you're on, and what browser you're using (if any). We'll get this sorted out.
Best,
Sara
I have the same problem. As with acrobat.com I could mark an item and then click on "delete". But now there is no such question mark possibility. Under that circumstances there is no reaction and no error message!
I use Firefox, Windows7.
Hi hugob,
Best,
Sara
Clearing the cache did not help. However, I tried to delete items with CHROME. There it works fine. It seems there is a general problem with the Firefox I installed. I will work on that problem. Anyway thanks for your help.
Rgs Hugo
Hi Hugo,
Glad you were able to delete your files with the Chrome browser. If you do find a solution to the Firefox problem, please let us know so we can share your solution with others.
Best,
Sara
Hi markhabatz49665374,
Which application are you referring to? If you're asking about the ExportPDF online service, please see Getting Started with ExportPDF | Adobe Community.
Best,
Sara
