Javascript in my .cfm works in IE but not FireFox..
Contributor ,
Nov 21, 2007 Nov 21, 2007
I can't figure out why this Node expand/collapse functionality works in IE, but will not expand/collapse in firefox. Any suggestions?
Advanced techniques
1.1K
Guide ,
I would suggest looking at Firefox's error console. Tools -> Error Console
But can I ask why you're using outerHTML? Usually the way to collapse or expand an element is to change its style. I don't know the exact syntax but something like
var elem = document.getElementById('IdOfTheElementYouWant');
elem.style.display = "none";
Advocate ,
Also,
Download a handy plugin named 'firebug' which will be quite useful for you to do these javascript debugging,
Here is the link,
http://www.getfirebug.com/
Contributor ,
Nov 26, 2007 Nov 26, 2007
The really odd thing, is this script works in Opera.. but still not firefox. Argh.
Guide ,
Like I said IIRC the standard way to hide/show elements is using element.style.display not outerHTML. A quick search suggests outerHTML is a non-standard IE property and is not supported under Firefox.
What does the Firefox error console say?
Contributor ,
Dec 04, 2007 Dec 04, 2007
Error Console says
Non-standard document.all property was used. Use W3C standard document.getElementByID() instead. and objDiv has no properties.
I'm kind of stuck, because I don't know much about Javascript.
Guide ,
Look at a tutorial on using element.style.display
http://www.w3schools.com/htmldom/prop_style_display.asp
Guest
All Gecko-based browers support the Microsoft's "innerHTML" property but none that I've heard of support the "outerHTML" property.
Firefox does not support document.all, use document.getElementById()
objDiv = document.getElementById('div' + id);
objImage = document.getElementById('image' + id);
This should work for both IE and Firefox
Contributor ,
Ok, I've replaced:
objDiv = eval( "document.all.div" + id );
objImage = eval( "document.all.image" + id );
WITH:
When I view in IE, it expands and collapses, but doesn't expand or collapse in Firefox. Now, when I look in Error Console, no errors are listed.
Do I need to replace outer.html? If so, what do I use?
Guide ,
One more time... there is no such thing as outerHTML in Firefox 😉 Its a MS property. It will not work in Firefox, et. al.
Can you post the full javascript code you're using to expand/collapse?
Contributor ,
Dec 05, 2007 Dec 05, 2007
Here's the javascript that I'm trying to fix. I'm not sure what to replace the outerHTML with to fix this, as it was written by someone else, and I hate to admit it, I'm not very good with javascript, so I really appreciate all your help. :-)
<script type="text/javascript">
// Node expand/collapse functionality
function expandNode( id )
var objDiv, objImage, strInner
strInner = objDiv.innerHTML;
if( objImage.src.indexOf( "plus" ) > 0 )
objDiv.outerHTML = "<div id='div" + id + "' style='display:inline'>" + strInner + "</div>";
objImage.src = "/img/minus.gif";
else
objDiv.outerHTML = "<div id='div" + id + "' style='display:none'>" + strInner + "</div>";
objImage.src = "/img/plus.gif";
</script>
Guide ,
Its not as complicated as you seem to be thinking. Like I said originally, there are two steps:
1. You get the element you want to expand or collapse
In other words: objDiv = document.getElementById('div' + id);
2. Then use the element's style to expand or collapse it
In terms of your code (collapse): objDiv.style.display = "none" ... or (expand)...: objDiv.style.display = "inline";
Documentation
