Can I create a topic hierarchy in the Project Manager pod or do I need to rely on the TOC?
Apr 15, 2015 Apr 15, 2015
Can I create a topic hierarchy in the Project Manager pod or do I need to rely on the TOC? I am using RoboHelp 9 (although I doubt the version matters).
Mary
290
LEGEND , Apr 15, 2015 Apr 15, 2015
Hi Mary
The way you do this is by creating folders in the Project Manager, then either create new topics inside the folders or move existing topics into the folders.
If you are working exclusively in the Project Manager, you are only able to move a single topic at a time. If you want to move a swarm of topics, open the Topic List pod and you are able to select as many as you want. Then drag the selected topics to the folder over in the Project Manager pod. Be a bit careful when dragging. Often, th
What’s a “topic hierarchy” look like & where do you want to see it? Just askin’ ;>)
Apr 16, 2015 Apr 16, 2015
I am guessing that you are being facetious. Not funny.
Hi Jeff,
Are you serious? If so, please be specific. Although I doubt that you are.
By the way, this (Project 'pod' topic hierarchy) is easily accomplished in Flare - without the need of extra folders. Please note my response to the Correct Answer. The answer which I had figured out - and was hoping RoboHelp had an alternative.
Mary
@mtcn3 - sorry, just had never heard the term "topic hierarchy" used within RH. Most of my projects are FM imports, so they automagically get "structured" when they appear within RH due to the book and chapter content that FM maintains. For the one project that I author directly in RH, I just sort of naturally created folders in the Project Manager to help keep the topics straight in my mind (they echo the structure of the application being documented). How does Flare accomplish this?
Hi Mary
If you are working exclusively in the Project Manager, you are only able to move a single topic at a time. If you want to move a swarm of topics, open the Topic List pod and you are able to select as many as you want. Then drag the selected topics to the folder over in the Project Manager pod. Be a bit careful when dragging. Often, the mouse will pass over a tab at the bottom of the pod and it may change views on you.
Cheers... Rick
Huh, who knew that I had topic hierarchies in my projects & I didn’t even know it ;>)
Thanks, Rick.
That is actually what I did - create folders and move topics into them. I also created a TOC - for a more streamlined navigation through the online help. (Otherwise, the folder names appear in the navigation, which is 'clunky'.) I suppose the TOC is also used for the creation of PDF output, although I am not sure. Anyway... it works... and I have a topic hierarchy - in my Project 'pod' and TOC.
Much appreciated,
Mary
P.S. Too bad there isn't an easier method of making a topic hierarchy in the Project. This can be accomplished in Flare without the need for extra folders. Oh well...
RoboHelp Documentation
Download Adobe RoboHelp
