says incorrect PW. reset PW, at adobe site and still won't let me erase, any suggestions? Probably should have said a little more. My authorization is not working. Says the password is wrong and I know it's not. I was told I need to erase the authorization file.Problem is to access that procedure you need to enter your password. So I thought I'd do a runaround and uninstall and re-install. Checked to make sure and files/folders linked to ADE were deleted. and they were. Shut down, instead of re-start, sometimes it helps. reinstalled ADE. Tried to erase the authorization same problem, invalid password. I can authorize with the password though. Obviously the authorization file is not removed during the uninstall process. Haven't been able to locate it so far.
You are facing the problem on Windows or Mac?
